04-26-2017, 06:57 AM | #1 |
Drives: 2007 yaris HB Join Date: Mar 2016
Door handle reatachment..
I removed and painted passenger side door handle.I put back together using this guide...
http://www.yarisworld.com/forums/showthread.php?t=5792 The star screw is tightened down but when I pull handle the mechanism does not engage,it is just loose...http://i.imgur.com/lMjQS9F.jpg It appears same location as what the drivers side is.Just looking for suggestions from anyone who has removed handles. Thanks again. UPDATE:sort of.. By the looks of this video the panel needs to be removed and there is a bolt @ 2:37 mark https://www.youtube.com/watch?v=s_AiJkjqSpU I will remove panel this weekend to see whats going on.Perhaps removing handle is the easy part but putting back on is another. The link above who posted here may have not explained the entirety of the process. Last edited by Pinchlite; 04-26-2017 at 07:47 AM. |
08-30-2020, 01:38 PM | #2 |
Drives: Yaris 2007 Join Date: Jul 2020
I did the same thing
the mechanisms did not engage |
09-11-2020, 05:26 AM | #3 |
I fixed
When I took the car handles off The mechanism for car outer door did work I had to open up inner door trim then reach inside with my hands And push grey lever down U simultaneously hold the rod that attaches to yellow When hold on rod the grey lever stay in place U then put in outer door handle inside There by outer door handle gets hook onto grey lever U check by pulling handles and Outer door handle spring back If does not spring back U got pull grey lever more This is for 2007 Yaris |
