Old 08-17-2018, 06:08 AM   #1
hondajt
hondajt's Avatar
Drives: 2013 Yaris LE 5Dr
2009 Yaris w/ 150K P0607 Code
Howdy!
Wife's 09 Yaris 5D w/ 150k is due for some love. I'm hoping to change the spark plugs this week. Anything else I should be ordering besides the spark plugs? I bought some new air filters (cabin and engine) as well. I can't do an oil change in my apartment complex's parking lot, so it's just light duty stuff.
I was hoping to not have to change the ignition packs because they are not something I budgeted for, lol; but if it's necessary than I will.
Thanks. Side note, I have the owners manual and read the regular service guide, and we are always ahead of the oil change schedule and fluid changes, and generally take good care of the car, I'm just trying to get my hands dirty a little to hopefully encourage myself to do more of my own car maintenance.
Looking for fun!
hondajt is offline   Reply With Quote
Old 08-17-2018, 05:43 PM   #2
B.B._07
Drives: 07 5dr
Don't change the coil packs, if they're not giving you problems there's no need to change them. At 150K I would check if the coolant and ATF have been changed.
Old 08-19-2018, 10:23 AM   #3
hondajt
hondajt's Avatar
Got a P0607 Code and previously I've had a rear O2 sensor code, but didn't think anything of it.
I'm replacing my air filter, spark plugs and PCV valve, and I don't think our EGR system can be replaced, but maybe I'll look into cleaning it?
No idea what to do about the P0607 though...
Looking for fun!
Old 08-20-2018, 01:27 AM   #4
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
I would replace Toyota transmission fluid, coolant fluid change , check drive belt
2007 yaris hb 192k miles
p0607 check for lose connections ecm , check all fuses , and reset the car by removing the battery or using scanner. see if it comes back, I would drive around local for if it comes back or not..
Causes
Possible causes of OBD code P0607 Toyota
A P0607 Toyota could be caused by one or more of the following: Loose ground terminal on PCM/ECM Dead or defective (12V main) battery An open or short in the power or ground circuit Loose or corroded battery terminals Failed PCM/ECM
yaris4062007 is offline   Reply With Quote
Old 08-20-2018, 01:28 AM   #5
yaris4062007
found this online
Possible Solutions
As a vehicle owner there isn’t a whole lot you can do yourself to diagnose this DTC. The first thing to check is the battery, check the voltage, inspect for loose/corroded terminals, etc., do a load test on it too. Also inspect the grounds/wiring at the PCM. If that’s good the other common fixes for a P0607 Toyota Control Module Performance DTC seem to be either replace the PCM or update (re-flash) the PCM with updated software. Be sure to check for TSB’s on your vehicle (Technical Service Bulletins) as there are known TSB’s for this P0607 Toyota code for some Toyota and Ford vehicles. P0607 Toyota Control Module Performanc If the PCM needs replacement, we strongly recommend you have a qualified repair shop / technician do the work, one that has the capability to reprogram the new PCM. Installing the new PCM may involve using special tools to program the vehicle’s VIN (vehicle identification number) and/or anti-theft information (PATS, etc.). NOTE: This repair may be covered under the emissions warranty so be sure to check with your dealer as this may be covered beyond the bumper-to-bumper or powertrain warranty period.
Old 08-21-2018, 09:04 PM   #6
hondajt
hondajt's Avatar
Thanks.
I've ordered the Denso iridium spark plugs, (#3324, SK16R11), new air filter, pcv valve, and some dielectric grease, so my battery posts don't corrode so easily.
I'm really concerned with the color of my accessory belt though...
Looking for fun!
2009 Yaris sedan problems BennyLava DIY / Maintenance / Service 5 12-26-2020 05:14 PM
Yaris 2 D4D 2009 without AC serpentine belt rasyaya DIY / Maintenance / Service 6 07-17-2014 09:02 AM
2009 Yaris and wind sailing GrayYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 10-26-2013 07:52 PM
Just bought: 2009 Yaris Sedan Prometheus Bound New YARIS Purchase Forum 2 05-11-2013 11:45 PM
