Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 07-29-2016, 01:25 PM   #1
baseballfan416
Drives: 2017 L 3-door
Wtb front passenger brake caliper bracket with slider bolts....
Replacing brakes this morning and one of the slider bolts on passenger side is essentially seized with the rubber boot almost completely shredded. Looking for a front passenger side brake caliper bracket (ideally with the bolts).
baseballfan416 is offline   Reply With Quote
Old 07-29-2016, 01:50 PM   #2
http://www.yarisworld.com/forums/showthread.php?t=57002
Old 07-29-2016, 03:21 PM   #3
baseballfan416
thanks for the link
Old 07-29-2016, 05:23 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Heat on the bracket where the slider pin is plus an impact gun to spin it out, after clean slider pin replace boot and clean the inside of the bracket pin area.
Sent from my ONEPLUS A3000 using Tapatalk
Old 07-29-2016, 05:25 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
But if your in Toronto, Collingwood area I have a spare one....you can have.
Old 07-29-2016, 06:50 PM   #6
Good advice and OP is in Wisconsin.
Old 07-29-2016, 10:41 PM   #7
baseballfan416
So the bolt moves but it only comes out part way... Are you guys saying I can technically reuse the bolt and bracket with a new rubber boot, assuming I can heat the bracket and actually get the bolt to come out?
Old 07-29-2016, 10:47 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yes, there is a 14mm bolt that goes into the slider pin...the bolt holds the caliper to bracket.
Now sounds like ur slider pin is stuck and I bet it's the lower one, just try to spin it out since it's moving while pulling at same time with pliers.
If completely stuck one needs to heat the bracket and than spin pin.
To answer ur question... Definitely one can reuse just make sure it's nice and clean, a drill bit works perfectly as long as it's same size as pin to clean inside the bracket, as for pin just wire brush.. Lube all with new boot and good to go.
Also the problem is do to no maintenance but mostly the stupid rubber insulator rubber ring at the end of the pin and I bet that is what is stuck, it's just for sound repression and really serves no other reason so don't use it.
WTB: 07 Sedan Front Grille combo + passenger headlight knockoutking Willing to Buy by private party 7 11-02-2009 10:26 PM
WTB - Passenger Side Seat Bracket lunjiaow Willing to Buy by private party 3 09-08-2009 05:03 AM
WTB: 07/08 liftback front passenger fender liner solarVitz Willing to Buy by private party 0 07-02-2009 07:22 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
Coilovers - creaking sound from passenger front? Gideon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 03-16-2009 03:20 PM
