02-21-2010, 03:22 AM | #1 |
Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
best free mod!! check it out!!
okay, so i've had my yaris for what? almost 2 months now? and only mods i did were interior lights and nice dent from shopping cart.....
that was, untill the other day, decided to check out my intake system. and yes, i did it, i upgraded my intake for free!! lol. it fixed almost all complaints anyone has had about this car: the car is a little louder at lower RPM's, its deeper soundingat any RPM, smoother idle (less idle searching), HP gain (how much i have no idea but you can feel it especailly in the lower RPM range), EVEN BETTER FUEL EFFICIENCY!! its alot more difficult to bounce the car between shifts, engine breaking is a bit better (nothing significant), RPMs drop faster once the throtle is released easier to coast in first at low speeds and RPM REVERSE IS A DREAM NOW!! (still grinds...nothing fixed there, but its smoother) i do realize jsut about everything i listed is due to a boost in HP but seeing as i don't have a dino i cant test it.... so anyways, i will describe what i did, i also took pics of the process. i really jsut want to note it cost me nothing because i had an extra yaris stock air box so if anyone has a reason as to y this is bad for my yaris i can pop mine back in..... please wait and see what ppl say about it before doing it yourself anyways, what i did is simple, almost brain dead simple..... i took my airbox cover off, inside there is a white filter that is attatched to the housing..... drill out the melted parts (mine had 6 melted circles) rip it out and remove the pipe from the bottom of the air box and there u have it.... lol. been thinking of drilling the hole bigger at the bottom but haven't decided yet..... my main question is what in the world did i jsut take out? lol, my car (300km since mod) has been running great with no engine lights or anything.... any thoughts? my conclusion was (seeing as its filled with rubber chunks) that it will stop a back fire from messing up my air filter.... so far i love it!! mind you, i do plan on getting a proper intake for summer
If it has boobs or wheels sooner or later your gonna have problems with it |
02-23-2010, 12:48 AM | #2 |
assuming no one knows exactly what was taken out??
02-23-2010, 12:53 AM | #3 |
Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
It's called a carbon trap. It traps the fuel vapors that come out through the intake when the engine is off for reuse. The tube that you took off is a silencer tube. All that does is tone down the noise.
Not sure about the Yaris, but with the IS-F, someone did dyno runs with and without the carbon trap. Results...decrease in hp without the carbon trap. I was really considering removing it, but after reading that, I decided not to. I removed my silencer tube, but didn't see any change. I never put it back tho. hahahaha. |
02-23-2010, 01:07 AM | #4 |
i find without the silencer tube the hole in the bottom of the air box is right after the cooling fan.....meaning some forced (or introduced) injection. lol. i notice for sure taking off something is better..... i think..... lol, any ways to test it without a dino? been thinking once the weather dryes up a bit doing a 0-60 and 0-100 test, an average with the trap and an average wqithout the trap.....
maybe its like stickers..... the more stickers you have on your car the faster it goes, lol. without the silencer and trap the car is a bit louder...... tricks me that its going faster..... so bottom line, nothing can really get damaged in my engine/ car due to this right? except if possibally too much fuel vapors get on my filter it could combust? lol
02-23-2010, 01:42 AM | #5 | ||
I don't suppose any damage will occur to your engine. The environment, yes. Oh, when the radiator fan kicks in, it's trying to cool the coolant/radiator itself, thereby dissipating heat within the engine bay. Since the hole we "made" by taking off the silencer tube is behind it, we're actually sucking up that heat. Like I said, I don't feel any difference other than noise. hehe. You can do what I did before. Take that silencer tube to a hardware store. Match the diameter of the bottom hole (the part that connects to the intake box) with some dryer tubing or any other flexible tubing (might be 2.5-3", not sure, I didn't measure it). Then you can stick and secure that tubing to where the silencer tubing connects to, and route the tubing down to in front of the bottom grill or behind the foglight/foglight cover (cut a hole in the cover if you don't have a foglight), thereby receiving fresh, cooler air. It may or may not add some hp. I didn't feel any difference when I ran this set up with a K&N drop in (carbon trap still in place). Quote:
02-23-2010, 01:43 AM | #6 |
If that's your car in your avatar, route the tubing to the bottom grill. Might want to put some mesh in front of the opening of the tubing too.
02-23-2010, 12:31 PM | #7 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
without that carbon trap in your intake your car does not meet the same emissions standards it did when it was on the lot.
someone correct me if I'm wrong. |
02-23-2010, 06:47 PM | #8 |
Oh, back to the HP issue, total HP or peak HP is probably lost..... But bottom end HP there is a gain for sure.... And really I'm not racing it so I think its good. Will try that cold air piping thing as soon as the weather clears up
