Old 12-26-2015, 04:01 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
DIY tool for fuel tank lid
There has been more discussion as of late about fuel pump and regulator access so here are a few photos of the DIY tank lid tool I made. 1" steel pipe. We cut a 3" section off of the length of pipe I bought and then sliced it down the middle to make two half moon sections. I then welded them as you can see so that they will grip the teeth built into the lid. The length of the bar is 30" to give plenty of ability for torque to remove/reinstall. I have used it probably well over a dozen times with no issues. Hope this helps people. This is a much cheaper alternative to the Toyota tool that costs hundreds of dollars.
Sent from my XT1575 using Tapatalk
Old 01-10-2016, 02:40 PM   #2
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
The new year has been mad busy but I have started working on the building of the tool now. Once it's finished I will upload some pictures too of how it works :)
My backseat passengers haven't been too thrilled with sitting on the soft, luscious chassis floor so I am determined to have this whole process done by the end of the month.
MedMantle is offline   Reply With Quote
Old 01-14-2016, 02:41 PM   #3
MedMantle
MedMantle's Avatar
Big thanks to fnkngrv for the help in creating the lid removal tool. I made mine today and it works perfectly. Just some pictures of it on the fuel pump access lid **
Old 01-14-2016, 02:49 PM   #4
fnkngrv
fnkngrv's Avatar
Awesome to hear that it worked out for you. Much better than spending hundreds of dollars for specialty tools.
Sent from m-o-b-i-l-e
DIY: 60/40 Split Seat Install (some welding required) CTScott DIY / Maintenance / Service 13 03-05-2017 04:12 PM
DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) CTScott DIY / Maintenance / Service 1 08-21-2013 03:57 PM
tool list silver_echo Off-topic / Other Cars / Everything else Discussions 5 10-21-2010 10:23 PM
