10-14-2015, 01:35 PM | #1 |
Drives: 2008 Toyota Yaris 2D Join Date: Apr 2014
Are there alternative jack stand spots? (08 Yaris)
2008 Yaris hatchback
I know where the jack points are in front and back for the floor jack, but i was wondering if there is anywhere else i can safely put jack stands without damaging anything besides the pinch welds behind the front tires and in front of the back tires. All i have for jack stands are ones that have a VERY slightly curved bar at the top, I tried hockey pucks with a groove cut into them under the pinch welds, but the hockey puck started tilting off the stand as i slowly lowered the car down. |
10-24-2015, 10:55 PM | #2 |
Drives: 2010 3dr LB Join Date: Sep 2010
When jacking my Yaris I use a 2"x8" board that allows me to lift the whole side at once. I would think you could do something similar when using jack stands. Bill C
10-25-2015, 10:10 AM | #3 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
I like to lift on the boxed section of the floor pan, sometimes called a subframe. This tread has some pictures for lifting the entire front or rear.
http://www.yarisworld.com/forums/showthread.php?t=9823 |
11-10-2015, 12:26 AM | #4 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
yes that is good places. also you can jack on the subframe/body bolts, and the center uni-body rail/frame. if you look underneath you can see some rubber body plugs where the vehicle was mounted on the assembly like, this is also a support area.
11-10-2015, 06:33 AM | #5 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
I finally got around to modifying modifying hockey push with an angle grinder. I'm lowered so I cannot aces the front lift point.
I usually jack my car up about twice a month so the pinch welds are not adequate for that. I now lift at the pinch welds using a puck and then place my jack stands under my control arms for the front (, close to the subframe , possible). For the rear I place the axle on jack stands this way there is no weight on the pinch welds. Worked well this past weekend with no issues.
No one ever wants to give a Yaris the point by... |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
How are you guys jacking up your Yaris? | touroxin | DIY / Maintenance / Service | 65 | 02-01-2015 04:42 PM |
What is it about the Yaris | Ranger SVO | General Yaris / Vitz Discussion | 18 | 01-06-2015 09:45 PM |
WTB: 2006-2008 Yaris Stereo Wiring Harnesses, AUX Jack | zerosktz | Willing to Buy by private party | 4 | 02-19-2011 02:41 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
