Old 11-10-2014, 01:21 PM   #19
Originally Posted by Eduardo_mty View Post
one question.
i will take the + wire, from reverse light, i will run from back to front.
one pin on the harness, is the reverse light trigger, then,
i will connect .. + wire from reverse light, + red wire from harness and +wire from pin trigger?
this is correct?
I would think that the + wire should get ignition switched +12 V power and the reverse wire would connect to the red back-up light wire. Does the documentation explain the pin trigger? I would think that it would be a separate way of turning the camera on (like when you are not going in reverse).
Old 11-10-2014, 01:26 PM   #20
Eduardo_mty
reverse trigger instruccions
http://www.autoharnesshouse.com/19867_add.html
Eduardo_mty is offline   Reply With Quote
Old 11-10-2014, 01:31 PM   #21
Ah, the reverse trigger is just the opposite of what I was thinking - It is an input to the head unit to tell it that the car is in reverse.
Old 11-10-2014, 01:34 PM   #22
Eduardo_mty
the trigger pin, is the #2 from left to right..opposite the "security clip"
Old 11-10-2014, 01:49 PM   #23
Eduardo_mty
harness position
Old 11-10-2014, 08:28 PM   #24
Eduardo_mty
I was thinking, i "resolve" my doubt.
the + wire from camera, i will connect to + wire from harness.
the pin trigger from harness to + wire from reverse light.
this is correct?
Old 11-10-2014, 10:21 PM   #25
this is correct?
Yes.
Old 11-17-2014, 08:01 PM   #26
Eduardo_mty
doubt about reverse trigger pin..
This is the reverse trigger that i marked with red line ??
see pict..
Old 11-23-2014, 07:48 PM   #27
Eduardo_mty
Today i was installed my rear view camera...
i was an error, with the connectors.. but the seller help me, and show me my error
pic 1 . the harness,
pict 2. my error
pict 3. left foot reverse wire
pict 4. correct pin connector for reverse trigger
pict 5. head unit show the camera image
Old 11-24-2014, 07:36 AM   #28
bronsin
bronsin's Avatar
I was walking around the block the other day and was almost runover by a Corolla backing out of its driveway. It was about 10 feet from the sidewalk and I didn't see the driver in the car or hear the engine running. As I walked behind it it suddenly started moving towards me. I screamed "Look Out!!!" and the driver stopped just as the rear bumper touched me.
Yeah it had a backup camera in it which the driver didn't look at. Not only that, even if she DID look I was completely out of the camera view walking from the drivers right to left.
So the camera only works if the subject is right behind the vehicle, not moving.
Just a heads up all you people.
Old 11-24-2014, 08:05 AM   #29
hondajt
hondajt's Avatar
Drives: 2013 Yaris LE 5Dr
^^I highly doubt anyone here is using the backup camera solely for safety. I only use one for parking in tights spots.
Looking for fun!
hondajt is offline   Reply With Quote
Old 11-24-2014, 08:15 AM   #30
Eduardo_mty
Plus the rear view camera, i will install rear back sensor, in 2 weeks
Old 11-24-2014, 08:57 AM   #31
bronsin
bronsin's Avatar
It shouldn't be used for safety at all! The driver needs to look themselves 180 degrees behind the vehicle when backing up.
Now that I think of it, if the camera is used in tight parking spaces for backing up and the driver doesn't do a 180 before starting to reverse they could run someone over who is moving towards the vehicle but is out of the cameras field of view.
Because of advertising on TV I imagine A LOT of people think of a rear view camera as a safety device.
Which it isn't!
Old 12-15-2014, 04:13 AM   #32
ucsmfu
Drives: yaris le
so your reverse camera works good ?
here's mine :)
ucsmfu is offline   Reply With Quote
Old 05-27-2015, 04:43 PM   #33
screenprinter
Drives: 2010 Yaris 4-door Sedan
Know this is older, but here's a couple of YouTube videos that show how to hook up a Reverse Camera. Nothing fancy:
Wireles:
https://www.youtube.com/watch?v=BqbxyvP3u8A
https://www.youtube.com/watch?v=SDrAacDFvFI
Adding the Camera Part 1: https://www.youtube.com/watch?v=LBzoD97BcHQ
Adding the Camera Part 2: https://www.youtube.com/watch?v=Y4owoUL8UDo
screenprinter is offline   Reply With Quote
Old 10-17-2017, 02:06 AM   #34
yarisbug
yarisbug's Avatar
Drives: 2010 1.4 d4d
Hate to revive an old thread, but i'm doing the same thing here with the exact same wiring harness and am a bit confused as to where/what i tap into to provide power to the camera; would I tap into the reverse light and wire that to the camera's power cable, or actually run a power wire from the camera itself all the way to the front and splice that into the red wire on the harness?
Any help would be greatly appreciated.
yarisbug is offline   Reply With Quote
Old 10-17-2017, 06:38 AM   #35
For the cam, I tapped into the reverse light wire in the taillight. The trigger for the head unit, I tapped into the red wire in the fuse box.
Old 09-15-2021, 12:17 PM   #36
phpist
Drives: Yaris III
I Will tray to install this Chinase Rear view camera (picture 1)
I try to remove this plastic, but i can't.(picture 2)
I found this connector, i think this is for rear view camera
what this really rear camera connector?
phpist is offline   Reply With Quote
