10-15-2017, 07:30 PM | #1 |
Drives: 2015 yaris le Join Date: Feb 2015
Should I replace this small piece of brake line?
I had worked on the master cylinder many times, and pushed it in and out with the lines attached to see if there is a leak. I had a stripped nut and replaced it by cutting the flare and using another nut I had laying around. I am just worried about the line near the back connecting to the mc. I moved it so many times, and when it was replaced, had a small kink from bending but no leaks. It moves from the bracket being moved. Should I replace it or leave it alone? It has been fine for the past two weeks.
10-16-2017, 07:35 AM | #2 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Well, it's not to hard to change that rear one. For peace of mind reasons.
10-16-2017, 06:55 PM | #3 |
Its pretty badly stuck on the union. Couldnt get it off with my flare wrench, and toyota makes you buy a set of lines not just one. I guess im better off leaving it if it isnt leaking.
Tags |
brake line, fluid, kink |
Similar Threads | ||||
Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
Will this hold? Plastic bag vs brake fluid | lamadoo | DIY / Maintenance / Service | 7 | 04-25-2013 03:35 AM |
Question on brake bleeding... | Yarflana | DIY / Maintenance / Service | 6 | 04-03-2013 01:55 PM |
Beware of the "simple" brake job tasks | Yarflana | DIY / Maintenance / Service | 7 | 03-18-2013 02:26 PM |
Front brake pad replace: calipers piston | dslc | DIY / Maintenance / Service | 3 | 07-17-2010 02:46 PM |
