01-11-2014, 01:57 PM | #1 |
Drives: yaris hatch 07 640K original m Join Date: Mar 2007
OCV valves
is there any reason to think that the new OCV valves available on the web are better than
the original ones on the 2007s. They sell them as a 1 piece unit ,mine is 2 pieces... |
01-11-2014, 07:26 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Where is yours split? The OEM ones are normally one contiguous unit.
01-11-2014, 09:04 PM | #3 |
on mine the solenoid is apart from the sliding valve...maybe it wasnt that way to begin with...
however the 07s were not well designed. I wonder if its worth it to buy an 09 -10 if it will fit.. |
01-11-2014, 09:30 PM | #4 |
They were the same with the same part number from 06 to present (2014). If yours is separated the most likely cause is someone prying against it while tightening the drive belt.
01-12-2014, 06:29 PM | #5 |
whats the cheapest one you know of new..??
01-12-2014, 08:09 PM | #6 |
The genuine Toyota ones can be had for about $55 new. If you are interested, I have one that I snarfed off an engine that only had 3,000 miles on it that I could do $50 shipped for.
01-14-2014, 04:16 PM | #7 |
thanks but I think I want new
btw that thing just allows oil flow to increase up the cam gallery... If you just took it off and sealed the hole ,would it be a big deal?? More oil would flow all the time ..so what.. Last edited by yaris9876; 01-19-2014 at 06:47 PM. |
Similar Threads | ||||
Yaris 2007, 1KR-FE valves knocking | Put-in | DIY / Maintenance / Service | 2 | 12-06-2011 04:00 AM |
Anyone care to make a DIY on break flushing and bleeding? | Hard_Yaris | DIY / Maintenance / Service | 19 | 05-04-2011 03:49 PM |
Valve's broken. | N3misiS | DIY / Maintenance / Service | 17 | 11-15-2010 04:35 AM |
Fuga de aceite en OCV | carlosh | Central and South America | 4 | 06-03-2009 12:08 PM |
BENT VALVES in the head: tell me how that happens.... | BLAZINBLUEVITZ | Off-topic / Other Cars / Everything else Discussions | 27 | 02-17-2009 04:49 PM |
