Old 05-05-2010, 12:29 AM   #1
fwynn
Drives: 1999 NHBP Honda Prelude
Wiring diagram?
Hey guys I did a search and I couldn't find it.. I'm trying to find a wiring diagram for the 09 Yaris Sedan. I'm trying to install an alarm system with the Remote start. I bought my girl a Viper 5901 system and would like to install it! :] I'm new in electrical kinda.. but i do know the basics as well as some details....
We took the car to a shop named Promax located in Alhambra, Ca.. and they COMPLETELY failed on the install... when they installed it... when the unlock button is pressed it beeps 3 times instead of 2 times.. when you drive the LED on the transponder box thing keeps beeping...(It's supposed to not flash when you're driving)... When the lock button is pressed it beeps once.. like it's supposed to.. HOWEVER it says there is a door open.. ALSO there are no lights that flash when the buttons are pressed..
They said it can be a defective box.. however once they told me "you're LED's may be interfering with the brain.. It may be draining too much power" (the LED's are in the dome light and map light. replaced them because the stock lights were not bright enough.. besides LED's take out less power than regular bulbs) I have the Clifford 50.7x on my car (Honda prelude) and i have LED's everywhere.. and it works perfectly.. so the LED part fails..
So I really need your help guys.. I saw the Remote start diagram thing :] but i also need the alarm part :]. Thanks!
fwynn is offline   Reply With Quote
Old 05-05-2010, 08:23 AM   #2
If you look in the DIY section of the forum there is a sticky thread with the complete 07 service manual. The EWD section has all of the wiring diagrams and there is no difference between the 07 and 09, as far as the connection points for the signals related to wiring an alarm. From your description above, it sounds like you really need the install guide for the Viper 5901, as it sounds like they connected its harness incorrectly and/or programmed it wrong.
Old 05-05-2010, 07:43 PM   #3
Palmer812
Drives: 2010 Meteorite Metallic LB
One tip for you. The Viper 5901 comes pre programmed for a manual transmission so if you are installing it on a car with an automatic you have to re program it before it will remote start.
Palmer812 is offline   Reply With Quote
Old 05-05-2010, 08:28 PM   #4
fwynn
oh WUT X__X
thanks for this tip! Where can i get it reprogrammed? Imma assume i should take it to an authorized viper dealer?
Old 05-05-2010, 09:00 PM   #5
Palmer812
If you are going to install it yourself you can reprogram it. The alarm comes with instructions on how to program it. If you don't want to do it yourself take it to a Viper dealer. We charge $130 for an alarm with remote start.
ECU Wiring Diagram? thebarber DIY / Maintenance / Service 15 08-12-2022 05:07 PM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 11:43 AM
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 6 04-25-2009 08:11 PM
Wiring color code for 2008 LB? charles nelson DIY / Maintenance / Service 0 04-25-2009 03:56 PM
NEED TPMS Wiring Diagram please mikenacarato DIY / Maintenance / Service 9 02-11-2009 11:55 PM
