Old 10-12-2015, 03:44 PM   #1
BennyLava
Drives: 1987 Silverado
Lining up the head lights '09
I need to raise up the headlight level on my 09 sedan. I've taken a few pictures, and I'd like someone here to maybe draw a little arrow on them, and point out the vertical and horizontal adjusters. Or if someone has a better pic, that would be fine.
BennyLava is offline   Reply With Quote
Old 10-13-2015, 09:53 PM   #2
BennyLava
Anyone? Is anybody still out there?
Old 10-13-2015, 10:29 PM   #3
For the sedan the adjuster is inboard and below of the headlight bulb. In your first picture it is the device just below the grey connector.
Old 10-13-2015, 10:43 PM   #4
bairjo
I prefer this...https://www.youtube.com/watch?v=NP0mQeLWCCo
Patients sometimes on this forum is needed...but you will get a response....usually, as in this case, from the master...CTScott.
bairjo is offline   Reply With Quote
Old 10-22-2015, 03:25 AM   #5
BennyLava
So its not actually visible in any of the pics I posted? There is one screw there, just making sure that's not it.
From your reply it looks like I could get to it easier, if I unplug that plug in the first pic. Would you say that the adjustment screw, is fairly easy to access?
Old 10-22-2015, 05:58 AM   #6
It is visible in the first pic. It is the device, which is a bolt with a large washer looking device under the head of it.
Old 10-22-2015, 11:36 AM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
Hm? Put a Philips head screw driver in the hole. That's the adjuster for height. There are no horizontal adjustments AFAIK. If you look down there, you will see it, it can also be adjusted with a hex wrench.
Sent from my A0001 using Tapatalk
Old 10-22-2015, 07:34 PM   #8
Attachment 56051
Correct - It is vertical only. There is no horizontal adjustment.
Old 10-28-2015, 12:15 AM   #9
BennyLava
Thank you sir. I have been trying to get a straightforward answer out of this forum for a long time. You're the only one who's ever just spit out this simple answer.
And with it i was able to adjust the lights. Thanks again
Old 10-30-2015, 07:16 AM   #10
BennyLava
Got this thread and this reply confused with another help thread I have on a different form.
That said, I noticed your reply says something totally different than his. You say its that one with the washer looking head, he says it those others. For me, the ones he said turned out to be the correct one.
So is the other one for something else?
Old 10-30-2015, 02:15 PM   #11
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Here. IllusionX circled the same thing except that the part he circled, the adjusting screw, isn't visible, it's behind that plastic. So it looks like he circled those plastic tabs.
Old 10-30-2015, 10:52 PM   #12
Hershey
I would use the horizontal mortar lines of a brick wall to get headlight height the same . Park car on level ground about 5 feet away from side of a brick wall at night and make adjustments .
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 12:01 AM
LED License plate lights for Yaris Sedan YarisSedan DIY / Maintenance / Service 6 04-09-2013 04:05 PM
Instrument Panel goes out if I turn on my lights ceceb DIY / Maintenance / Service 9 07-08-2010 05:56 PM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
