Old 04-12-2006, 03:33 PM   #55
GD-RS
GD-RS's Avatar
Drives: Black Golf...for now
Well see, that my thing too! I know this car isn't exactly built for speed so I'm not going to spend too much time or $ trying to tune it, but at the same time, I do want to get the most out of it.
According to most posts on this topic smaller and lighter is better, so I've been looking at 15" Konig Heliums which weigh like 10lbs. However, compared to the 17" Motegi DP12's (21lbs!!) they look like they belong on a dinky car.
I have no idea what to do...
GD-RS is offline   Reply With Quote
Old 04-12-2006, 03:51 PM   #56
birdy
I stay G'd Up
birdy's Avatar
Drives: 02 wrx wagon
Send a message via AIM to birdy
you can always get your fenders rolled to fit an 18x8.5 rolling them usually give you a good hafl inch extra.
birdy is offline   Reply With Quote
Old 04-12-2006, 05:40 PM   #57
birdy
I stay G'd Up
birdy's Avatar
actually does anybody have a straight on pic of the optional trd rims? I want to see what somethign looks like.
Old 04-13-2006, 01:49 AM   #58
Ron
Drives: BBM Yaris HB
this is what i'll be using: http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg
Ron is offline   Reply With Quote
Old 04-13-2006, 09:34 AM   #59
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
There are plenty of relatively lightweight 17's out there as well.
All BBS wheels are relatively light, as are OZ wheels. You just have to look around.
Old 04-13-2006, 10:27 AM   #60
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Personally, I wouldn't put anything bigger than a 17 on my Yaris. I had 18s on my xB, and the handling and acceleration wasn't as good as the 16s I replaced them with. Plus, the 16s offer less rotational mass and unsprung weight. With only 106 hp, I think an 18 — even a lightweight 18 — is too much for the 1NZ-FE. This is of course all perofrmance-based opinion, not looks.
Old 04-13-2006, 02:27 PM   #61
LAHAL
LAHAL's Avatar
Drives: 07 Yaris RS B package Manuel
so question. i don't know much about wheels, actually i know nothing. i know what spacers r, but does this really help with not having the wheel rub? just a question, and does anyone have a pic of what rolling a fender means?
Thanks
LAHAL is offline   Reply With Quote
Old 04-13-2006, 02:47 PM   #62
why?
why?'s Avatar
Drives: Yaris LB
Spacers will help the inside of the wheel not rub in corners. Basically they will increase the positive offset of the wheels.
Old 04-24-2006, 10:54 AM   #63
why?
why?'s Avatar
Drives: Yaris LB
Does anybody know if +35 offset wheels would be okay for the Yaris. More specifically, 14x5 +35 wheels.
Colin Chapman disciple
Old 04-24-2006, 11:23 AM   #64
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
it'll probably fit...you might need a spacer for the front because it might rub the caliper, but test fit it.
the back is more than fine...you'll actually probably need to get a 10mm spacer to fillin the wheel well
why such small wheels?
Master is offline   Reply With Quote
Old 04-24-2006, 03:46 PM   #65
why?
why?'s Avatar
Drives: Yaris LB
Weight.
The +45 wheels weigh about 1/4 lb more for each wheel.
The 15x5.5's weigh almost 1 lb more.
I'm not going to race the car, and I believe I can find a set of tires that will handle well enough for me.
Oh, plus there is nothing wrong with 4 wheel drifts.
Old 04-24-2006, 04:26 PM   #66
SmellyTofu
好多人&
Drives: .
You mean decrease positive offset.
SmellyTofu is offline   Reply With Quote
Old 04-24-2006, 06:49 PM   #67
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
http://www.tirerack.com/servlet/Call...pecial=Pricing
whats the weight on those? i looked all over but hte right places.
and what do you think of these
-- Blen
EDIT: and what are also good tires? brandwise. And also these wheels.
http://ww2.vividracing.com/catalog/p...8ab9365e578fb3
And also i hope they bring some Halo Rings for the heatlights and few cool taillights. no doubt bout that, the tailights isnt sexy.
Old 04-24-2006, 09:08 PM   #68
Blenjar
Blenjar's Avatar
What's the difference between 18x7 and 18x7.5
Is it a big differences?
1: I'm new to this so I can it plain and simple, which size will not reduce the performance out of the Yaris HB?
2: And if there is a way to put the biggest rims on and doing something to fix the issue about the wheels touching what in the where of the car, what will it be and cost? is it worth it tho?
Thanks in advance.
-- Blen
Old 04-24-2006, 11:38 PM   #69
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
you can fit 18x7.5 with a 45 offset running a 215 40 18 wheel.
you might have to cut or roll the fender as well as heat gun the front plastic molding where it'll probably hit when you turn the wheel to the max.
in all it should not cost you more than 100 bucks to do all of that. the fender rolling should be around 50 bucks and you can just buy a heat gun, use it, and return it :)
Old 04-24-2006, 11:38 PM   #70
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
oh and you guys care too much about wheel weight, but that's just me.
you have no idea how silly 14 or 15 inch aftermarket wheels are gonna look :)
Old 04-24-2006, 11:53 PM   #71
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
You have no idea how silly you look to all of us.
Idjiit is offline   Reply With Quote
Old 04-25-2006, 12:11 AM   #72
Blenjar
Blenjar's Avatar
so for the wheels i can fit 18x7.5 with 4x100 should be what I'm looking for? well then again the wheels gets heavier..16,17 looks more right...
Anyone knows the lbs on the O.Z. Record?
