06-01-2010, 02:59 AM | #1 |
HELP!!! HEADLIGHT QUESTION
So I put a HID kit in 3rd day and then they go out. I check the wires its good. The actual connector where the stock lights plug into look a lil damaged like... fried =\ So I put the stock ones back in the and the passenger side works but the drivers side is really dim?!?!!? Did I totally screw up the plug for the lights? I need help nowwwwww
06-01-2010, 05:46 AM | #2 |
Drives: Yaris RS 2007 Join Date: Oct 2006
i got the same problem b4, and i took my car to the dealership and they just replace a fuse or a relay then it back to normal
don't forget to put your stock light and bulb back b4 you take your car to the dealership |
06-01-2010, 08:07 AM | #3 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Check the H-LP LH fuse (in the under hood fuse panel).
06-01-2010, 08:50 AM | #4 |
Sweet, thanks. I'll check the fuse box. And then if that doesn't work I guess I will have to take it to the dealership =\
06-01-2010, 10:16 AM | #5 |
If that doesn't work, let me know and I'll point you where to look next. As long as you have a volt meter it should be pretty easy to track down the problem.
06-01-2010, 11:22 AM | #6 |
You sir are a genious =D I checked the fuse and it was blown. So I put the horn one in there for now. Never liked the way horn sounded anyways =P
06-03-2010, 10:59 AM | #7 |
Yaris = <3
Drives: '08 Sedan - Flint Mica Join Date: Jan 2009
Lol
..:'; Nick ;':.. ============================== 2008 Yaris Sedan - Flint Mica ============================== Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter ============================== |
Similar Threads | ||||
DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 04:13 AM |
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison | CTScott | DIY / Maintenance / Service | 54 | 02-14-2011 08:58 AM |
How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 02:12 AM |
Headlight adjustment screw question. | evan | DIY / Maintenance / Service | 6 | 01-09-2009 05:58 PM |
Quick headlight question | silverRS | Cosmetic Modifications (Exterior/Interior) | 3 | 06-21-2006 09:54 AM |
