02-13-2009, 01:39 PM | #1 |
Drives: 2008 Black LB Join Date: Dec 2008
Cheap Spring Install
I have been looking for the cheapest place in the St. Louis area to get lowering springs installed, and so far haven't found anything I would call cheap. Does anyone in the area have any suggestions? Thanks
02-13-2009, 02:14 PM | #2 |
do it yourself!!! all the cool kids are doing it, there is a write-up on here telling you what to do, rent the tool from autozone and you are good to go, cost is free
02-13-2009, 02:16 PM | #3 | ||
Start another Oil Thread!
spring compressor? it's not needed
02-13-2009, 02:28 PM | #4 |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
I used a spring compressor on the fronts, although like Tamago said, it's not really needed. If you want a bit of extra safety you can use it. They're usually free to rent at Autozone/Shucks/Kragen/Checker ($50 refundable deposit).
On my xB, the fronts literally did not need a compressor. My Yaris front struts were under a bit more pressure, though.
Subcompact Culture: The Small car blog |
02-13-2009, 09:40 PM | #5 |
I would love to do it myself, but my apartment does not allow automotive work to take place in the parking lots... and I have no mechanical skills
02-13-2009, 10:25 PM | #6 |
Projekt Sreet Tunzers
Drives: white yaris s with intake and Join Date: Feb 2009
that sucks buy the spring and go to a shop and see if they can do it for u or just go to a friends house and do it there
02-14-2009, 12:30 AM | #7 |
The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
I understand your apartment issue. But you don't have a friend that is a gearhead? All guys know at least one person that knows something about cars. I am NOT mechanically inclined, I am just a cheap bastard, thats why I work on my own car. Nonetheless, changes the springs are almost the easiest thing you can do next to changing the motor oil.
The best way to describe, its almost like changing a hard drive, you have to move certain parts out of the way to change one piece and then put everything back together. |
02-14-2009, 02:34 AM | #8 | |
02-14-2009, 05:12 AM | #9 |
02-14-2009, 10:12 AM | #10 | |
i never thought i'd see a harddrive and suspension compared to each other. . i've officially reached the end of the internet...
02-14-2009, 05:11 PM | #11 |
wow really 63x larger then u must be weak if u can pick up a box with springs in it
02-14-2009, 10:50 PM | #12 |
Similar Threads | ||||
Suspension install: Spring Compressors? | Thirty-Nine | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 09-18-2007 10:59 PM |
TANABE DF210 Spring Install [pics] | Chris07LB | DIY / Maintenance / Service | 148 | 07-16-2007 09:26 PM |
