Old 07-10-2019, 03:06 AM   #1
toyotavios_11
Drives: Toyota Vios
Should crossmember be dropped to replace sway bar bush?
here i mean yaris 2006 model
recently i found that it squeaks loud when go over speed hump so i wish to replace both pieces but i see the space is very compact to let the ratchet to access the sway bar cover bolts
toyotavios_11 is offline   Reply With Quote
Old 08-08-2019, 05:44 AM   #2
toyotavios_11
Drives: Toyota Vios
does anyone know it?
Old 08-08-2019, 07:20 AM   #3
ex-x-fire
I never done one on a yaris, I have on other cars that way. Its your choice if you want an alignment or not.
Old 08-08-2019, 10:40 AM   #4
tmontague
tmontague's Avatar
I'd recommend it to avoid stripped bolt heads. Alternatively you can try without removing the subframe.first and if it doesnt work, then go and lower it.
Old 08-09-2019, 11:53 PM   #5
toyotavios_11
Drives: Toyota Vios
today i remove front tire and have better view on sway bar bush bracket bolts. i conclude that to remove the bolts you have to drop the crossmember.
2005 echo sway replacement sway bar meemadd Performance Modifications 7 08-15-2016 11:56 PM
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
WTB: Weapon R Dragon Intake and TRD rear sway bar. TerenceCruz Willing to Buy by private party 2 07-28-2013 05:13 PM
sway bar links contd jstantherprsn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-26-2011 02:58 PM
Sway bar and struts DOMAV Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-17-2009 02:26 AM
