05-03-2013, 03:53 PM | #1 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
Is the cutoff RPM or Speed?
simple question as that. I noticed that at 113 MPH the car loses power but i have been 117 MPH before. so was it supposed ot cut off at an RPM or at a speed?
Rev-limiter or Speed-Limiter?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
05-03-2013, 04:27 PM | #2 |
Drives: 07 Yaris Turbo Join Date: May 2007
Both.
Rev limiter is 6250, speed limiter is approximately 115. It's possible to "cheat" either one a little depending on driving conditions, as shown by varying reports.
05-03-2013, 07:38 PM | #3 | |
Problem, officer?
Drives: '06 Yaris 5DLB 1.5 Join Date: Oct 2010
I heard that pulling the parking brake just 1 click will override the speed limiter. But I really didn't notice the effect. Maybe that was the fastest my Yaris will go . |
05-04-2013, 09:43 AM | #4 | |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
^ He is right to a point. It is actually 118 which is programmed into the stock ECU. The major catch here is how Toyota actually performs both limiters which is probably the easiest way for them to do it and and that force the fuel system to go stupid lean which really isn't good for the engine. Not saying that you will blow up a totally stock motor after hitting the limit too much, but it will increase wear/tear on it. Just something to be aware of. I honestly have no idea how other manufacturers do it, perhaps it is the same
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
01-01-2014, 04:59 AM | #5 |
Drives: Yari Join Date: Dec 2013
Hello guys,
can anyone help me..I just did an engine swap using 1nz-fe 1.5L. unfortunately, I experienced the engine cut off at around 2500-3000 rpm. Thanks in advance. |
01-01-2014, 05:12 AM | #6 |
Drives: toyota yaris yrs Join Date: Jun 2007
01-01-2014, 09:26 AM | #7 |
Drives: No more Yaris Join Date: Dec 2013
Okay...so there IS a engine-speed limiter in the computerized fuel-injection/emissions system?
I didn't know that. |
01-01-2014, 02:53 PM | #8 |
Yes....the way the ECM handles via the speed sensor and cluster is that once the speedometer returns that 118 has been reached then the ECM leans out your fuel drastically to "force" you to reduce speed. I found that it would drop me depending on the suspension setup (for example wheel/tire combo) I could lose between 8 on the high end and 4 on the low end of mph lost. I found this out over 20+ land speed runs which gave a great way to figure it out. Essentially riding off the speed limit cut is a bad thing.
01-01-2014, 04:57 PM | #9 | |
I have an automatic and no tachometer. From time to time, once every couple of years or thereabouts, I have cause to be in the Rockies. I don't like to ride the brakes down long downgrades; with a manual and tach it's of course easy to monitor RPMs. And shift. With an auto, if 3 doesn't give enough engine braking, I might want to use 2 - but shifting in and out of it is gonna be hard on the motor mounts. I don't want to over-rev when climbing short upgrades. ...as well, once I got my floor mat lodged on the accelerator pedal with my manual - as I was running up the gears. Engine ran away when I got on the clutch. It was my 2009 and brand new at the time; and I'd always wondered if I'd over-revved it (of course I was too busy trying to figure out what was going ON at the time to be staring at the tach). So...speed only? Or RPMs, also? |
01-01-2014, 07:00 PM | #10 |
According to what we saw during the dyno pulls the rpm limiter was forcing into lean conditions as well however the behavior was different as you don't necessarily lose power as you do when you hit the speed limiter.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 | RPM JEFF | Great Lakes | 0 | 09-24-2012 04:40 PM |
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 | RPM JEFF | Mid-Atlantic | 0 | 09-24-2012 03:10 PM |
LOW RPM @Idle speed = Bad Volt Generation? | jp_costarica | General Yaris / Vitz Discussion | 4 | 06-14-2012 04:56 PM |
The most economical speed for the Yaris. | Ilovemyyaris | Fuel Economy Forum | 3 | 03-19-2012 11:33 AM |
RPM at 60 mph 5 speed manual | mark schofield | DIY / Maintenance / Service | 13 | 10-08-2011 12:14 AM |
