07-27-2010, 11:54 PM | #1 |
Drives: 2007 Yaris 4d Sedan Join Date: Feb 2010
Help - Rust on steel wheels
I live in colorado, and I think that the salt they throw down in the winter and just the general enviroment have been a big factor in my steel wheels starting to rust.
Does anybody have any advice or a solution to making my wheels look new again? I'd like to fix it before it gets any worse - it's making my yaris look trashy Below are a couple shots of 3 of my wheels. |
07-28-2010, 12:10 AM | #2 |
Drives: 07 Yaris sedan Join Date: Jun 2007
Yeah, get at them soon! I take mine off, sand the rusty spots, wire brush the rest, and use a quality marine enamel to repaint them.
Alternative is to take them off, take the tires off, and have them sandblasted and powder coated: end of problem for as long s you own the car! Mind you, with all that salt, the wheels may be a lesser problem. |
07-28-2010, 08:10 AM | #3 |
Drives: 07 Yaris Sedan Join Date: Jan 2009
I swear, the wheel covers are made to scrape. Toyota should issue a recall. Each Yaris I see has the same problem, unless it's right off the dealer lot.
07-28-2010, 09:38 AM | #4 |
Drives: 2008 yaris, stripped, red Join Date: Jan 2009
for all the time you'll spend you may as well have the 'coated.
powder is awesome, and you'll never have a problem again. |
07-28-2010, 10:04 AM | #5 |
Drives: new vitz Join Date: Apr 2010
best thing is to remove the rust and to re paint it
07-28-2010, 01:29 PM | #6 |
After researching more - I think I'm going to sand and paint with something glossy (I think it ends up looking pretty sharp and then I can get rid of the scrapped up hubs). Any suggestions on pain/primer, and sand paper grit?
07-28-2010, 01:32 PM | #7 |
Drives: Yaris Join Date: Oct 2008
You should get some rust converter to spray on after you've sanded off the rust, it will stop any rust you miss from spreading, and leaves you with a flat black surface thats ready to paint without a primer.
07-28-2010, 03:18 PM | #8 |
Thanks for the tip markitect - thats probably a wise thing to do!
07-28-2010, 08:52 PM | #9 | |
Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Not sure if it is a spray on or paint on. Then, you can paint over that as suggested. |
07-29-2010, 02:28 PM | #10 |
ooo ooo ooo....por-15. awesome stuff, you'll never have another rust problem, even in the lug holes. check it out
http://www.por15.com/ they also have an anodizing kit that's called por-10, and you can even anodize chrome to different colors. how cool is that... |
07-31-2010, 08:08 PM | #11 |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
I agree,sandblast...powdercoat.Folks often neglect their rims and other out of reach places on their vehicles....take the wheels off at least once a year and clean/wax them as you do the vehicle....brake dust,salt etc are on these surfaces too.
08-01-2010, 03:38 PM | #12 |
Thanks for all your posts - it's been helpful.
I think I found some stuff on amazon that I'm going to use - it's going to take me a little while to get to it since I'm moving soon, but when I do finish I'll post some pics for sure. Hopefully this will help other people out, as I'm sure I'm not the only one with this problem. |
08-11-2010, 02:18 AM | #13 |
Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Remove hubcaps wash steel wheel with soapy water and rinse. Wipe dry and scuff paint and rust with scotchbrite pad and wipe off. Mask off tire with masking tape and newspaper. Spray with Permatex rust reformer. Let cure overnight. Rust will turn black. Spray with satin black exterior enamel and let dry. Done.
08-12-2010, 12:15 AM | #14 |
I quit the masking tape/newspaper thing years ago. Get a strip of aluminum flashing from the lumber yard, a couple of clothespins, and make a permanent (and adjustable) mask. Pics if I am lucky...
I use a lazy susan bearing (buy it from the lumber yard as well) to set the wheel on, so that I can rotate it while spraying; makes a nice, even coat. |
08-14-2010, 07:48 PM | #15 |
Nice!
Similar Threads | ||||
Factory Original 15" steel wheels & hubcaps $19.99 (4 available) | cliftback | Items for Sale by private party | 14 | 04-01-2011 06:13 PM |
FS: Stock steel wheels and hubcaps | letstry1234 | Items for Sale by private party | 0 | 06-22-2009 12:31 PM |
2006 Scion Xa steel wheels... | Chupacabra | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 12-07-2008 06:52 PM |
KYB shocks and Steel stock wheels | White Yaris | Items for Sale by private party | 15 | 11-18-2008 09:26 PM |
15 inch steel wheels | Bretsuaz | Items for Sale by private party | 6 | 03-24-2007 08:25 AM |
