03-02-2011, 01:56 AM | #55 |
Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
4x6 should fit in the hole in the door but u will need a mount plate of some sort. i put a 6" in front and it still needed a mounting plate (used 1" think plywood)
If it has boobs or wheels sooner or later your gonna have problems with it |
03-02-2011, 05:28 PM | #56 |
That's what I figured, thanks. As for the dash adapter, does it matter the years on these cars? I can't seem to find one that specifically says 2011.
03-02-2011, 05:39 PM | #57 |
as far as i know interior hasnt changed. the 08 tim fit my 2010 so u should be okay there
03-03-2011, 01:18 AM | #58 |
Cool, thanks, now I just have to find one
02-06-2012, 08:17 PM | #59 |
Drives: 2007 Toyota Yaris Hatchback Join Date: Jan 2012
Just curious if anyone ran into this problem with replacing the front door speakers with the template pdf. I used a 3/4 in piece of wood which is like half the thickness of the factory bracket but now I cannot fit my door panel back on, it appears to be hitting something, but with such little space it is hard to tell what it is hitting the speaker or the template itself. Any idea would be helpful.
Brian |
07-20-2012, 09:54 AM | #60 |
Drives: 2009 Yaris hatchback 4 door Join Date: Jul 2012
What about speaker sizes for a 2009 Toyota yaris 5 door hatchback? I see this thread was started a number of years ago. Has the sizing changed at all? Thanks!
07-26-2012, 10:35 PM | #61 |
2ZR swap. DO IT! Ask how!
As far as I know, speaker sizes haven't changed since the '07 restyle. The bigger issue will be finding speakers that fit into either the stock shell or the Scosche SAT6. My Polk DXi650's will not fit in either, so I'm going to make some from sheet plastic or cheap cutting boards.
08-31-2012, 06:48 AM | #62 |
Siberian
Drives: Yaris Sedan S 2007 Join Date: Feb 2012
just finished replacing of stock speakers in front doors of sedan'07. "why Toyota use this type of speakers?" - was the main question of this work)))) Who knew the answer?
now i'm happy with Kicx alq6.2 )) wooden spacers helps me))) |
08-27-2013, 11:05 PM | #63 |
Drives: yaris Join Date: Aug 2013
I think the one is great :DVD Radio Special for Toyota Yaris - Navigaiton Digital TV DVB-T
02-26-2014, 11:11 PM | #64 | |
Drives: '09 Yaris 5 door Hatchback Join Date: Feb 2014
http://www.youtube.com/watch?v=aIHr3qXCJxk |
03-29-2015, 02:47 PM | #65 |
Drives: 2008 Yaris 3 Door Manual Join Date: Mar 2015
So I purchased the Scosche TA02B car stereo adapter (which only has 2 connectors. Today when I took my factory radio out, it's got 3 plugs, not 2. What gives?
03-31-2015, 03:00 PM | #66 |
Drives: 2009 Yaris Sedan 5spd Join Date: May 2009
Nice 6.5" template - am wondering if anyone has a template for the 6x9 / sedan adapter?
(Lots of sites sell adapters, but I got a small CNC & 3D printer - eventually I want to make my own adapter). |
05-31-2015, 10:27 AM | #67 |
Drives: 2007 Toyota yaris Join Date: May 2015
2007 Toyota yaris wiringnhelp!!!
OK i got a 2007 Toyota yaris and I want to change my factory deck, not sure if it will matter but my factory deck is silver instead of black like I had seen on YouTube, and when I was looking for a wiring harness there is ones with and without the factory amp to power the two back speakers, so what I'm asking is what wiring harness do I get, its the 4 door hatchback so any help is greatly appreciated
Thanks in advance |
05-31-2015, 10:56 AM | #68 |
05-31-2015, 06:42 PM | #69 |
Thanks illusionx but also another question, will i need an amp interface to keep the chimes? I never wired one of these and i never needed one, but the two other cars i wired a deck for was a 2003 subaru impreza and a 2003 saturn ion so i guess they didnt need them, and thanks for the quick reply
Again thanks in advance P.s. the part number i was looking at is metra TYTO-01 |
06-01-2015, 12:27 AM | #70 |
This part is designed for aftermarket radio install if you have a build in amp like the JBL or mark Levinson audio system in the Lexus.
05-23-2017, 07:51 PM | #71 |
Drives: White '07 3dr LB Join Date: Jun 2016
Anyone installed a pair of Rockford P1650 speakers in their front doors of a 2nd gen 3dr HB ? RF website specs states 2.24" mounting depth, just want to make sure the door have enough depth to fit these speakers.
Thanks |
05-30-2017, 07:11 AM | #72 |
Drives: yaris 2009 Join Date: Nov 2014
I really want help here:
I replaced my factory front speakers with a pair of jvc cs-j620x in my 2009 HB yaris. The music is a lot clearer now, but the bass is terrible. So what should I do now? Buy an amp? Change the HU? Soundeadning the doors? I am all stock right now. I don't want bass that will keep my neighbors awake. I just want some decent music depth. Please suggest Sent from my iPhone using Tapatalk |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
aftermarket stereo kit? | xCookiE | General Yaris / Vitz Discussion | 4 | 02-16-2006 10:33 PM |
