Old 02-15-2019, 03:20 PM   #1
Yotato07
Drives: 07 yaris standard 5 speed
Really rough idle wont stay running 07 yaris 1.5l
Howdy y'all so the other day My Gurdy ate some ole ladies ass on the freeway was able to drive it home no coolant leaks or anything but she wouldnt idle at all had to keep on the accelerator ir she would just die ran really rough @2000rpm and below anyways could use some help troubleshooting this thanks
Yotato07 is offline   Reply With Quote
Old 02-15-2019, 04:32 PM   #2
2bz
Drives: 2008 Yaris 3DR Hatch MT
What codes are your reading?
2bz is offline   Reply With Quote
Old 02-15-2019, 05:41 PM   #3
Yotato07
Dont have a code reader
Old 02-15-2019, 06:07 PM   #4
Yotato07
But until I cleaned the Maf it was not giving me a check engine light just the maintenence required light.
Old 02-15-2019, 06:48 PM   #5
2bz
Until you know what codes you have, you/we are guessing. Buy an OBD2 reader.
https://www.amazon.com/dp/B00YVHGTBM...xoC5CEQAvD_BwE
Old 02-15-2019, 07:04 PM   #6
Yotato07
Shit that thing is tiny and cheap here I was thinkiklng id have to shell ot a few bills
Old 02-15-2019, 07:40 PM   #7
Yotato07
So turns out my buddy had one the whole time anyway this is what came up
P0300
P0501
P0702
P0904
P0116
Old 02-15-2019, 08:47 PM   #8
Yotato07
So upon closer inspection i found a hole in my intake manifold
Old 02-16-2019, 07:43 AM   #9
2bz
Looks like you have lots of stuff to work on:
P0300 Random/Multiple cylinder misfire detected (likely caused by the hole in the mani.)
P0501 Vehicle Speed Sensor Range/Performance (transmission or sensor problem)
P0702 Transmission Control System Electrical (trans. slipping/low fluid)
P0904 Transmission Gate Select Position Circuit (ECU doesn't know what gear the trans is in)
P0116 Engine Coolant Temperature Circuit Range/Performance Problem (Tstat problem.)
Replacement intake mani.
https://parts.longotoyota.com/oem-pa...xoCqGIQAvD_BwE
Old 02-16-2019, 01:23 PM   #10
Yotato07
Gurdy is a manual trans so I think i can disregard all the tranny stuff
Old 02-16-2019, 02:50 PM   #11
2bz
Wait, what? No. Gurdy is throwing codes indicating issues with the trans itself or the trans sensors (the sensor could be misbehaving due to having internal metal particles on them.) I wouldn't disregard anything, especially after an accident.
Old 02-16-2019, 03:04 PM   #12
Yotato07
Well I'll replace the manifold and radiator then go from there, thanks for the help by the way its much appreciated
Old 02-16-2019, 05:46 PM   #13
B.B._07
Drives: 07 5dr
You probably damaged some wiring going to the transmission in the accident and hence the tranny codes. You can get a good look at the transmission by taking out the battery and air filter housing. I'd also check under the car for any leaks from the transmission or just check the fluid level.
Vibration, occasional high idle, and other shenanigans in 2009 auto Yaris hatch firebird1999us DIY / Maintenance / Service 21 01-30-2019 10:43 AM
Rough idle when hot Ravnica General Yaris / Vitz Discussion 4 12-19-2016 02:38 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
