Old 04-02-2012, 02:56 PM   #1
jonhy_ sm
Drives: Yaris '07
yaris 2007 1.0 MAP sensor
hi guys!
can someone tell me where the map sensor is located on the 2007 yaris 1.0( 1krfe engine) ?
How can it be cleaned? The same way you clean MAF sensors?
Show me some pictures indicating its location if you can.
Regards
jonhy_ sm is offline   Reply With Quote
Old 04-02-2012, 04:16 PM   #2
It is located under the air filter box and just behind the throttle body. From what I have heard, MAP sensors are not as fragile as MAF sensors, so most people clean them with carb cleaner or brake cleaner.
Old 11-16-2016, 01:16 PM   #3
sfumair
Drives: Yaris 2007 1.0 sedan cvt
thank you I have been searching for this, at least past 2 hours
sfumair is offline   Reply With Quote
Old 03-03-2018, 05:17 AM   #4
Bazilwasp1970
Drives: Toyota yarris 1.0 2008
Hi there. You have only been looking for the MAP SENSOR. Try 4 days. I looked every site to find out where to locate the MAP sensor on (1 KRFE engine) but all YouTube clips showed every other module but ours. At thanks to this forum I will be attempting to clean it. Can I use STP brake parts cleaner as I have seen a YouTube clip showing some one using it? Also can anyone send a image where to locate the PCV VALVE? Thanks
Bazilwasp1970 is offline   Reply With Quote
Old 03-03-2018, 05:18 AM   #5
Bazilwasp1970
Sorry for missing words. It’s the freezing cold weather to blame ��
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
