Old 07-31-2009, 04:58 PM   #37
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
Originally Posted by ezhacker1 View Post
LMAO o come on. you dont need to take off the bumper. just take off all the black push pin things, then fry the bumper towards you to get to the 3 screws that hold the headlight assembly in place. then its easy peasy. All this in 5 min or less.
O this is the dreaded HB yaris too.
Makes me wanna scream.
Labour cost was $64... sharmota!
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
Old 07-31-2009, 05:47 PM   #38
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Ouch that seems like a ripoff. Considering ezhacker is right ... all you have to do is undo the bumper clips, unscrew the headlight and then remove the bulb ... maybe takes 10 mins per light.
I agree though, it was pretty lame from an ease of use point of view. They make you never want to change the bulbs lol.
devinlamothe is offline   Reply With Quote
Old 07-31-2009, 06:09 PM   #39
Jem_hadar
MORDSITH
Jem_hadar's Avatar
What annoys me is that yall are saying you DONT HAVE to remove the whole bloody bumper... so why the f*ck would they determine that they had to??
10 mins your way vs. almost an hour their way (w/ bumper removal)
WTF
Even more annoying is that I tried myself (and as well with the help of a more DIY-savvy friend) to do this, but could end up getting the clips off! Ugh (and we tried and tried for like 15-20 mins... those couple on each side were such little bitches to get at! ARG)
Old 07-31-2009, 07:02 PM   #40
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
yeah the bumper clips (not the black push pins) on the side are pain. i was scared of cracking the bumper, but force is definitely necessary to get it off.
o and i figured this route out after i took off my bumper to get to the lights ....lol
Check out my Build thread:
Old 07-31-2009, 09:02 PM   #41
WTF
They follow the service manual procedure, which says to fully remove it. Theoretically flexing the bumper could cause it crack or whatever.
I pulled my bumper once to change the bulbs and a second time to install fogs. Fully removing the bumper only takes 5 to 10 minutes. when I changed my bulbs I was completely done in less than 30 minutes and that included taking a bunch of picture of my car with it off and checking out all the things I could see with it off.
They probably were done even quicker than that, but hit you with a minimum labor charge.
Old 08-02-2009, 01:01 PM   #42
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Agreed on both parts, unfort.
Old 08-02-2009, 01:41 PM   #43
PhilD424
Drives: Red Yaris
Reason why all of you are having problems with the rear drums wearing out and not being properly alligned is because you guys aren't using your handbrakes when you park.
-Phil
PhilD424 is offline   Reply With Quote
Old 08-02-2009, 01:47 PM   #44
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I use the handbrake every single time, actually most times, thats all I use.
My rears still wore out in 63-64k miles. thats not bad.
Old 08-02-2009, 01:48 PM   #45
PhilD424
Drives: Red Yaris
The Japs always have to do things the hard way which is one of many reasons why I hate japped cars. What a stupid design.
-Phil
Old 08-02-2009, 02:12 PM   #46
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I agree that it's stupid, but like I said the good old 1940 Ford was far worse. Try adjusting the valves or replacing the clutch on one of those American classics.
Old 08-02-2009, 04:18 PM   #47
devinlamothe
I don't think so ... I always use my handbreak when I park. Although I've developed drum problems around 110k km so it may have prolonged it ...
Old 08-02-2009, 04:46 PM   #48
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Non.
I've use my parking break absolutely EVERY single time I've ever parked my Yaris. Absolutely. Every. Time.
Jem
Old 08-02-2009, 06:07 PM   #49
Jem_hadar
MORDSITH
Jem_hadar's Avatar
just to let you guys know , the first time is always the hardest to remove the bulb , you have to get rid of that super tight membrane then you have to play around with your fingers to unclip the spring. when you have done it once all the other times will be like sliding through butter.....
Thanks for commenting this... bc I believe im gonna try harder to change them myself next time i have to replace a front bulb.
Old 08-02-2009, 06:11 PM   #50
90tsi
90tsi's Avatar
Drives: 09 yaris
so if I told everyone that i can change the bulb out on both sides of my car with out removing anything sound crazy? thats how i did all my bulbs on my 07 and 09. I didnt find it that bigga deal... even when i did my HID conversion on both of them.
90tsi is offline   Reply With Quote
Old 08-02-2009, 06:16 PM   #51
90tsi
90tsi's Avatar
Drives: 09 yaris
yea but as much dielectric as toyota uses i think that you could pack a set of bearing, lube ball joints and tie rod ends lol.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
Willing to buy : Left Headlight hasher22 Items for Sale by private party 3 06-05-2007 03:17 AM
