08-07-2022, 09:13 AM | #1 |
Drives: Toyota Yaris Hybrid 2019 Join Date: Aug 2022
Tire pressure warning light always on
Hi
I have had this problem for some time now and searching the internet it says to insert the ignition key without turning the engine on. Problem is is that this is a keyless model so no ignition slot. Any help would be appreciated please Thanks |
08-07-2022, 10:14 PM | #2 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
I think you may have a bad battery your wheels in in your wheels
08-08-2022, 06:52 AM | #3 |
08-08-2022, 07:26 AM | #4 |
Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
TPMS sensors have a battery in them. When the battery fails the sensor stops communicating with the system and the dash light is triggered.
08-08-2022, 09:34 AM | #5 |
08-08-2022, 09:36 AM | #6 |
OK it says online that TPMS batteries are not replaceable. I'll have to order a new sensor and I know which wheel is ths issue
08-08-2022, 10:26 AM | #7 |
Whenever I see a post such as this, I'm forever grateful none of my vehicles have TPMS. Given the outrages cost of a sensor, I'd probably just live with the dash light being on. Then again, I happen to live in an area that does not require annual MOT inspections.
08-08-2022, 10:46 AM | #8 |
Drives: 2009 Yaris 2dr Liftback Join Date: May 2019
Honestly, if you have never changed a TPMS before, just take it to a shop.
Otherwise, be prepared to remove and remount a tire, and then figure out how to get the ECU to recognize the new sensor. |
08-08-2022, 12:44 PM | #9 |
Yeah good luck with that! I bought a truck with a bad ABS module but the dealer I bought it from fixed it before I took possession. It cost $700 and took a week for the ECU to recognize the new part
08-08-2022, 08:34 PM | #10 |
Drives: '09 Yaris carmine red 2d HB Join Date: Jun 2009
I had the same problem on my '09 Yaris.
I replace all the TPMS sensors when recently getting new tires. They arr not cheap to replace but that light started to annoy me. I do not know about the UK but, in the US " Mavis Tires" specializes in replacing the TPMS sensors, That is where I got the tires. |
08-09-2022, 09:06 AM | #11 |
Online the sensor is coming up at around £40 so not too bad
08-27-2022, 09:17 PM | #12 |
keep in mind that is once one goes bad, you most likely will not know which one it is..... and if one battery goes dead the others are on borrowed time.
So you just might as well replace all four and be done with it. Of course,the best time to do this is when replacing tires. BTW, I believer that E40 is just for one and does not include programing and installing Last edited by RedRide; 09-02-2022 at 08:31 PM. |
08-28-2022, 03:11 PM | #13 |
Drives: . Join Date: Mar 2019
Just did the TPM bypass.
08-31-2022, 02:49 PM | #14 |
Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
I had to change the TPMS sensors in my previous Yaris, and I had it done at Costco for around $250 for all 4 tires. Take it to the dealership and you'll be paying a lot more.
09-02-2022, 08:29 PM | #15 |
Doing a bypass just disables a good feature. Good tiers are not cheap either.
BTW, it's a given not to go to the dealer. Last edited by RedRide; 09-05-2022 at 11:09 PM. |
Similar Threads | ||||
Help with Tire pressure light | nerdyguy | DIY / Maintenance / Service | 1 | 02-26-2014 07:18 PM |
NITROGEN GAS TIRE FILL: WORTH IT? | EjDaPogi | Middle East | 15 | 03-20-2011 02:06 AM |
LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
Higher Tire Pressure | captainm27 | General Yaris / Vitz Discussion | 46 | 01-27-2009 10:17 AM |
The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
