Old 05-13-2010, 05:01 PM   #1
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
Sedan Back Seat Fold Down Button
Hi,
I am not sure what to call this but I was wondering if anyone know how if this a relatively easy repair, not sure if its a simple part replacement or a whole new seat.... it appears you can get into the seat from the backside, I went to pull it and it just broke... I see nothing of this mentioned in the repair manual.
Ron
198K Miles
N9QGS is offline   Reply With Quote
Old 05-13-2010, 07:00 PM   #2
BLH
Drives: 2007 Yaris Sedan
Mine has a slider on each rear seat inside the trunk.
It can be locked so the button you broke can't put the seat down.
I guess so no one inside the car could access the trunk if you had it locked with the opener next to the driver seat bypassed.
BLH is offline   Reply With Quote
Old 05-13-2010, 08:19 PM   #3
Brian
Brian's Avatar
try these:
lock, seat back (R) 72630-52130 - $28.29
(L) 72640-52120 - $46.90
Bezel, lock (R/L) 72679-20030-B1 - $10.52
Prices are from the Toyota parts list and are probably cheaper from Sparks.
Old 05-13-2010, 10:05 PM   #4
N9QGS
N9QGS's Avatar
I don't necessarily want to lock the seat, I use the access on trips to grab stuff out of the trunk that i pack so its accessible from inside. :-) But I can say I have only used this latch button you pull probably a dozen times, I was shocked when it broke off but from the parts listed below it looks like a simple fix. I could not see picture of these parts but I will take them to the dealer and run it by them, I may open up the seat and inspect the whole assembly prior. All I really need is the whole stem and knob you grab, Im not sure if that extends several inches down the seat to where the latch is...
198K Miles
Old 05-14-2010, 07:49 PM   #5
Brian
Brian's Avatar
Here's a parts break down of the rear seat.
Old 05-22-2010, 12:27 AM   #6
N9QGS
N9QGS's Avatar
Okay I ordered the button, I fixed it in less then 2 minutes in the parking lot, two screws under the plastic guide that your seat belt runs through, and lefts off, and then the post with the broken part left inside, screws right off, and the new button screws on (making sure you put it through the plastic thing, and then screw the 2 screws back down. Amazing simple repair. Ron
198K Miles
Old 05-22-2010, 12:32 AM   #7
YAR1S
YAR1S's Avatar
AWESOME!
-Jen <3
Old 05-22-2010, 08:49 AM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
Nice going.
Help!!!! Back seat removal? shambala9er Cosmetic Modifications (Exterior/Interior) 1 06-11-2009 01:32 PM
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 10:28 PM
