Old 03-10-2015, 11:02 PM   #19
KingForADay
KingForADay's Avatar
Drives: 2013 5 dr. Liftback Yaris LE
I'm not mechanically inclined (I've only ever replaced spark plugs, batteries and headlight bulbs on other cars) and the bulb in the temperature control A/C knob is burned in my newly purchased 2013 5 door liftback. It's not a huge deal because at night I can just feel for the little indicator divot to see where the temp is at, but I was wondering how much would be a reasonable charge to have these bulbs replaced in the future by a professional.
I can generally follow step by step directions fine, but I'm nervous about breaking one of the plastic clips...and taking things apart and putting them back together just as they were isn't a forte of mine in general.
It'd probably be best to change all three if I do end up having it done I'm guessing.
Also, they're LED bulbs which are generally supposed to last longer than the life of a car, so is there a reason it burned in the first place and seems to be an issue that a number of people have in this part of the Yaris?
KingForADay is offline   Reply With Quote
Old 03-11-2015, 06:23 PM   #20
KingForADay
I should add that I noticed today that the orange A/C indicator light works on that knob, it's the temperature indicators that I can't see at night on the same knob. So I'm not sure if it's the bulb or what anymore.
Old 03-11-2015, 06:56 PM   #21
It is a separate little tiny bulb. There are a few threads on here with pictures of what they look like and how to change them on a 2nd gen Yaris. For your 3rd gen it would be basically the same. There are LED replacements for them and I believe there is a thread on here with LED bulb info that also lists them.
Old 03-11-2015, 08:36 PM   #22
KingForADay
Thanks very much for the info CTScott. I'm not mechanically inclined so what do you estimate would be a reasonable charge for a mechanic to replace all 3 bulbs with LED lights that I would supply?
Old 03-11-2015, 09:17 PM   #23
It should only take one a couple of minutes, but they would likely hit you with a minimum charge (30 minutes or so).
Old 03-11-2015, 10:27 PM   #24
KingForADay
Great, thanks so much for the info!
Old 03-10-2016, 08:58 AM   #25
Hassan619
Drives: toyota yaris
Hi. I've got problem with my climate control panel ..anyone know how to open it and how to change the light.. because their is no light in them.. or anyone know what the problem with the light ..toyota yaris 2009
Hassan619 is offline   Reply With Quote
Old 04-04-2016, 01:46 PM   #26
Adikoric
Newbie
Drives: 2010 Yaris 1.0VVT
Originally Posted by vinny121 View Post
Thanks all for your help. For the sedan, I had to remove the 4 black screws around the radio to get access to the AC control panel. Thanks for the pics of where the bulb is located. For the climate control knob, it is not obvious which clips to separate to get access to the bulb. Any ideas? This may help:
Is It the same for 2010 model? My central knob is the only one not working..
Adikoric is offline   Reply With Quote
Old 02-25-2017, 09:13 AM   #27
jeeper5usa
jeeper5usa's Avatar
Drives: 2011 Toyota Yaris
How can I change the Rear Defroster light bulb? I want to change to a different color and have the controls all pulled apart, just cant figure out how to disassemble the switch to get to the rear defroster light bulb???
jeeper5usa is offline   Reply With Quote
Old 03-06-2017, 02:41 AM   #28
spookybathtub
Drives: 2007 Yaris HB
I changed my lights for amber LEDs to match the display of my ham radio. I prefer the amber overall. But one downside I hadn't considered: The blue half of the temperature knob goes completely dark, since it filters out all the amber. So I left that one green. These are the LEDs I bought. If I did it again, I would choose a brighter one, because these are a bit dimmer than stock.
https://www.ebay.com/itm/261568290270
spookybathtub is offline   Reply With Quote
Old 03-07-2017, 09:34 PM   #29
spookybathtub
I must have broken something while doing this mod. Now the fan only works on setting 1. When I try 2, 3, or 4, I hear a click and the blower stops. I'll have to open it up again this weekend; hopefully it's nothing major.
Old 04-12-2017, 10:45 AM   #30
Ingrillato
Drives: Yaris D4D 2008
Clima lightbulbs Yaris MY 2006
Hi!
I'm Claudio an italian boy who lives in Sweden. I'm owner of a 2006 D4D Yaris.
I'm trying to change lightbulbs of climate panel but I'm not sure the lightbulbs you talk here fits with my Yaris MY 2006.
Is there anyone who can help me?
Thanks!
Ingrillato is offline   Reply With Quote
Old 01-21-2018, 06:03 PM   #31
Tarahw82
Drives: 2012 Toyota Yaris
I know it’s been a couple years since anyone posted in this thread, but I have a 2012 Yaris sedan and I only have one of the climate control dials lit up because the other two burned out. I saw the T4 T4.2 NEO Wedge LED lights on eBay. Will they still work?
Tarahw82 is offline   Reply With Quote
Old 02-02-2018, 04:25 PM   #32
scott4banger
Drives: 2013 Yaris Le US
The process ct scott commented on works with the 2013 dash layout too also same t4 bulb. 😀
scott4banger is offline   Reply With Quote
Old 09-28-2018, 08:21 AM   #33
tornyhurtle
Drives: Yaris Sport
2015 Yaris
Hi
I have just bought my 2015 Yaris Sport and my climate control panel only has one outside bulb working (the press button ones do)
I am like Wreck it Raplh when it comes to repairs, is it easy to do this myself and how does the panel come off please.
Sorry for sounding hopeless, need to know where to get bulbs also, is ebay ok
Thanks for the help
tornyhurtle is offline   Reply With Quote
Old 10-16-2018, 11:00 PM   #34
Brick
Drives: 2007 Base Sedan
For future reference I have confirmed that at least the 2009-2013 corolla bulbs match. I’m sure many other Toyota’s match too. I didn’t want to pay for new bulbs and instead went to the junkyard and pulled them out of the corolla, saving me a few dollars.
Brick is offline   Reply With Quote
climate bulb replace
The electronic climate control displays mrbond In Car Entertainment + Electronics (audio / video / alarm) 43 04-18-2021 03:34 AM
Digital Gauges, Auto Climate control, Manu-matic shifter computerlove87 Cosmetic Modifications (Exterior/Interior) 21 12-02-2012 11:55 PM
Yaris 09 climate control lights alt_k1ll3r DIY / Maintenance / Service 2 11-11-2008 10:19 PM
Bulbs For Behind The 3 Climate Control Knobs razzorjet2 DIY / Maintenance / Service 2 04-06-2007 10:41 AM
