Old 06-28-2017, 02:46 PM   #73
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Necro Thread this for someone asking about it
-Derrick-
Old 10-25-2017, 02:58 AM   #74
bizzlebaby
bizzlebaby's Avatar
Drives: 4 Dr 07 Sedan
does this mod apply to a 07 sedan or just the hatchbacks?
bizzlebaby is offline   Reply With Quote
Old 12-17-2017, 07:32 AM   #75
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
I'm going to do it on his sedan . I ordered the signals from China
I like very much travel
MickZEL is offline   Reply With Quote
Old 01-08-2018, 11:59 AM   #76
Pinchlite
Drives: 2007 yaris HB
Finally found this thread.
Door Connections:
There is a single 5-wire connector on both the Yaris and xD/xB mirrors. Three wires are used for the mirror movement and the other two are for the turn signal. On the Yaris mirrors, that connector only wires in 3 positions.
The picture below is of the Scion mirror connector. The red black and white wires are the motion wires (and they directly mate to the wires with the same functions {but different colors} on the Yaris).
The blue (ground) and yellow (+12 V) are the turn signal wires. Because the indicator is an LED, the polarity is important (i.e. they won't light if you reverse them). On the 06-08 Yaris, the connector on the door has no wires in the positions of the blue and yellow, so you must connect a wire to each and run it through the door, through the rubber boot, and into the car under the kick panel. You have to two wires, since the sheet metal of the door is actually not grounded to the rest of the chassis.
Attachment 42241
On the 09+ Yaris, there is a violet wire in the position of the blue mirror wire and a white/black stripe wire in the position of the yellow wire. These wires run through the door to the kick panel connector, and then dead-end at a junction connector way up under the dash. Since they save the hassle of running the two wires through the door, it is worth while to use them. The two wires have to be reversed at the connector though, since the white/black stripe wire is grounded at the kick panel.
In this picture of an xD mirror plugged into the connector on a 2010 the yellow wire (+12 to the LED) is connected to the white/black stripe wire (chassis ground). You can flip the blue and yellow wires by popping the pins or by simply cutting the wires and reconnecting them to the opposite wire (as shown in the second picture below):
Attachment 42243
Attachment 42242
Kick Panel Connections:
Access the kick panel by simply pulling up the door skid plate and then pulling the kick panel cover straight back.
09+:
Connect a wire to the violet wire shown below on the drivers side (note that there are two violet wires on that connector, so insure that you are on the correct one). Run the wire up to the under dash fuse panel area.
Attachment 42244
Connect a wire to the violet wire shown below on the passenger side (note that the passenger side connector only has one violet wire). Run the wire under the dash across to the under dash fuse panel.
Attachment 42245
On the 09+ the ground connection is already complete with the connection of the blue wire to the white/black stripe wire.
06-08:
Run your door wires to the kick panel area. Connect the wire that is connected to the mirror's blue wire on either side to the 10mm ground bolt in the kick panel using a 1/4" ring terminal. Run the other wire on either side to under dash fuse panel.
Fuse panel Connections (all years):
Connect the left side wire to the light green wire in connector 4B-14.
Connect the right side wire to the dark green wire in connector 4B-31.
Attachment 42246
Attachment 42247
Why not just wire to side markers.Thats what I will be doing.
Old 07-21-2019, 02:10 PM   #77
HighmileYaris
HighmileYaris's Avatar
Drives: 2009 Yaris S
Just got mine wired up and working... Slightly disappointed with how they perform in day light. But they are more than visible at night.
HighmileYaris is offline   Reply With Quote
Door Handle LED DIY with pics window_lee DIY / Maintenance / Service 93 05-31-2012 11:58 PM
My ebay fog lights and led interior light pics Julz Photo-Video-Media Gallery 6 09-13-2007 10:41 AM
Hi-Res Scion xD pics Yaris Revenge Off-topic / Other Cars / Everything else Discussions 27 05-04-2007 11:16 PM
