Old 12-09-2018, 05:25 PM   #1
Alain93
Drives: Yaris 12
Sticky clutch pedal
Hello,
Started yesterday, the clutch pedal is sticking down there, really annoying.
When I push down and release, it comes back half an inch and stop, then I have to remove pressure and it goes up suddenly.
Do you think it's the clutch master cylinder? already bad after 50000 miles.
Alain93 is offline   Reply With Quote
Old 12-10-2018, 10:27 AM   #2
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
Originally Posted by Alain93 View Post
Hello,
if your really hard on a car thats not designed for performance im not suprised probably. just swap it out.
DarkShadowFox is offline   Reply With Quote
Old 12-10-2018, 05:43 PM   #3
dogsridewith
Drives: 2007 2-door hatchback
Bleed clutch
I'd at least bleed the clutch first. (Read threads here on this.) For me and others here it brought up a too-low engagement point a bit...and we got some grit in the bleed fluid. I like to run the right front wheel up on a ramp first to put any bubble closer to the bleeder. (Low ramp...lots of ramps are too steep for the Yaris bumper. This vehicle tilting is not in the shop manual, and I've never seen anyone mention it anywhere.)
Old 12-11-2018, 12:34 PM   #4
Alain93
Drives: Yaris 12
ok guys thanks.
Do you know where I could get a repair manual for 2012?
it's like pass 2011 this car does not exist
YARIS Clutch Pedal Noise mik23 DIY / Maintenance / Service 3 04-27-2022 08:41 AM
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Squeaky Clutch Pedal? Kaotic Lazagna DIY / Maintenance / Service 43 05-29-2016 01:15 PM
Clutch pedal assembly interference with foot Connoisseur_of_fine_cars General Yaris / Vitz Discussion 4 09-23-2011 10:57 AM
