08-29-2014, 07:53 AM | #19 |
Maybe just an upgrade to a 1NZ manifold and throttle body might be all the upgrade you need. It would make sense that the 2NZ TB is smaller than the 1NZ.
Sent from my iPod Touch |
08-29-2014, 11:42 AM | #20 |
play every day
That's an excellent suggestion.
An issue would be converting from cable to drive by wire. If I had a cable, I'd stick with it. The throttle response is so much better than electronic controls. Greg |
08-29-2014, 03:28 PM | #21 |
08-29-2014, 11:02 PM | #22 |
Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
Sounds good, still trying to source a 1NZ intake manifold. How far off is a 2ZZ intake manifold in terms on bolting up to our NZ engines?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
08-30-2014, 12:45 AM | #23 |
play every day
08-30-2014, 06:00 PM | #24 |
2ZR swap. DO IT! Ask how!
The TB on my 1st gen Sienna was a 4-bolt cable style. I think I've seen some in the junkyard before. No idea if they're the same bolt pattern, and I'm sure they're HUGE compared to the one he already has.
08-30-2014, 06:16 PM | #25 |
08-30-2014, 07:05 PM | #26 |
Crap. Now that we've completely derailed the thread, perhaps we can figure out if a 1NZ intake manifold would work?
08-31-2014, 06:59 PM | #27 |
I'm sure it will, I just need to find one first.
How far off are the inlet ports between an 2zz manifold & a NZ engine, Do you think an adapter would make sense?
08-31-2014, 08:03 PM | #28 |
A 2ZZ manifold will not fit a 1NZ or 2NZ. It's ports for one are probably close to twice the size and is designed for an engine with an 8000+ RPM redline.
08-31-2014, 09:04 PM | #29 |
Mr. 155 and climbing
1nz intake manifolds can be found easily. if anything ypu can find them all the time on facebook groups with folks from PTR on them.
08-31-2014, 10:21 PM | #30 | |
Find me for cheap and I'll love you forever
08-31-2014, 11:21 PM | #31 |
What do you consider cheap? You do realize that you are saying this in a Yaris community so in my book cheap is very relative....seems like expensive here is cheap elsewhere
08-31-2014, 11:33 PM | #32 |
A new one is $100 on ebay so $50 for a used one seems reasonable
09-03-2014, 12:45 AM | #33 |
I can sell you my stock intake for 50 plus shipping. only thing is it wouldn't ship for a week due to business travel.
09-03-2014, 09:07 AM | #34 |
Just PM me when you get back
10-29-2014, 09:27 AM | #35 |
I finally got around to doing the swap (3 bolt cable TB) yesterday, here is what I discovered;
The 1ZZ TB Requires longer bolts A special 'gasket' had to be made The Throttle Cable is it's stock position is too short The car idles EXTREMELY high, minimum of 2000 RPM > http://youtu.be/XTNK8QxzM08 I'm still troubleshooting, hopefully I'll get it sorted out.
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin Last edited by Ryze268; 10-29-2014 at 03:22 PM. |
10-29-2014, 11:33 AM | #36 |
You'll need to back the idle adjuster screw off a bit. It's set to idle a 1.8L.
Similar Threads | ||||
wtb stock throttle body , cheap | blacksandiegovitz | Willing to Buy by private party | 0 | 09-21-2012 10:32 PM |
THROTTLE BODY SWAP NO CEL!!!! | kou | Performance Modifications | 53 | 02-01-2011 04:01 PM |
FS- 1ZZ Throttle Body, Spacer, NST SSK | MGargano | Items for Sale by private party | 9 | 09-01-2010 08:48 PM |
Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
toyotafest 2007 | esquiva | Photo-Video-Media Gallery | 36 | 05-15-2007 12:03 PM |
