Old 03-15-2009, 05:33 AM   #1
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
DIY : How to remove door panels
This is my contribution to Yarisworld. THis is what I am cataloging as I am going along with my yaris build. I am hoping it might help somebody.
This is done on a liftback 2009 Vitz RS.
Starting on the left hand door.
Remove the armrest piece. It just pops upwards.
This is just another illustration of the same piece that should pop up. On the other end of the door, use a small screwdriver to pop open a cover as shown in the photo.
This is what it will look like after taking off the piece.
Proceed to remove the power window switch panel and the other panel illustrated in the photo. These should both pop up as well. No tools required, just use your hands.
Remove the connector for the power window switch by pressing the tab and pulling.
This is what it looks like after removal of the above 2 pieces.
+ screwdriver required. Remove the 4 screws as shown in the photo.
To remove the door card, I pulled anywhere along the bottom of the door. It will come apart as shown.
It might require quite a yank to get it to come off. After it has seperated from the door, push the door card UPWARDS, it should come free after that.
Remove the door / lock wires from the latch.
These are where all the little grommets are located in order for you to re-attach them to the door card for installation. ***There is one more behind the hand.***.
I hope this help. :)
FEINT is offline   Reply With Quote
Old 03-15-2009, 11:27 AM   #2
hahah I just did that this morning from an old DIY, but arigato, your pics are quite clearer!
Old 03-15-2009, 12:44 PM   #3
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Ok, now I have no excuse for not pulling my door panel off to do sound deadening. Thanks for the DIY.
Old 03-15-2009, 10:53 PM   #4
djgoodonya
the ubernigga
djgoodonya's Avatar
Drives: 2008 Yaris 3D HB MT
Agreed. Can't wait for consistent nice weather. Poor Type R's are just sitting in the closet uninstalled.
djgoodonya is offline   Reply With Quote
Old 03-15-2009, 10:57 PM   #5
ChinoCharles
Drives: LB
Note that if you have manual windows its a little tricky to remove the crank.
Old 03-16-2009, 12:39 AM   #6
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
I did the deadening yesterday, so here's a little DIY again.
I took off the plastic sheet then I had to remove all that sticky black silicon. I used selo tape and just stickied it off.
All done, nice and clean
Then applying the sheets should be pretty straight forward. I am going to have to re-do mine as I am not happy with the way it turned out.
Old 03-16-2009, 01:20 AM   #7
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Did you put any deadening material on the inside of the external door skin or just cover those holes on the inside as seen in the photo?
Old 03-16-2009, 04:48 AM   #8
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
External skin deadened, but didn't have time to take a photo. I am not finished with the deadening yet, waiting for my speakers to arrive. Then I have to get baffles and then I will deaden the door again and also over the baffles.
Old 05-25-2009, 11:08 PM   #9
Astroman
Modded Moderator
Astroman's Avatar
Where is the DIY for the manual windows? Trying to figure out how to get the crank arm off.
Old 05-27-2010, 03:36 AM   #10
privateyeblckbx
Should be a spring clip behind the crank handle. Push on ur panel slightly and look behind and should see a horse shoe shaped clip. You can either remove it with a special tool which is the easiest (Harbor freight or autozone for about $5-14) or a flat screw driver or a pick will work. Careful they shoot out sometimes and are easy to lose. Pretty sure the yaris is the clip type (i have power windows), if not it can be a cover type that u remove and swing out of place to reveal a torx screw or bolt.
privateyeblckbx is offline   Reply With Quote
Old 11-30-2013, 01:11 PM   #11
Lars
Yaris beginner
Drives: Yaris XP9F
The pictures are dead :( Can anyone repost or something? I'm getting some new speakers soon :)
Lars is offline   Reply With Quote
Old 11-30-2013, 02:14 PM   #12
Here http://www.yarisworld.com/forums/sho...+panel+removal
Old 03-26-2018, 10:11 AM   #13
Pinchlite
Drives: 2007 yaris HB
photos???
What images?
Old 11-18-2021, 02:16 AM   #14
KermitAUS
Drives: Yaris 2009
Following
KermitAUS is offline   Reply With Quote
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
DIY Powered USB Ports BailOut DIY / Maintenance / Service 27 02-22-2017 10:17 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
