12-17-2010, 07:22 PM | #1 |
Drives: Toyota Yaris meteorite silver Join Date: Jan 2009
HIDs
ran into a little problem... Im not to sure where to connect this wire thats in my hand i think it goes to the battery but idk
12-17-2010, 07:25 PM | #2 |
there for the head lights H4 also the h11 has the same ones also
12-17-2010, 08:00 PM | #3 |
Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you should have a bulb adapter harness...unless you bought a cheap kit...or you can make a harness/relay setup and run power/ground to the unit. or, you can use the headlight harness adapter to power the unit but it's not as reliable.
dont mix up power ground or you could chance blowing the unit. you can use the headlight harness to power the relay and run the relay directly to the unit....is how i'd do it. |
12-18-2010, 10:36 AM | #4 |
thanks for the replyi got it from garm so u know its good stuff the only thing is is that the h11 hid fogs didnt come with a relay cord or anything im not sure if there supposed to but im gonna shoot a email to garm
12-18-2010, 06:27 PM | #5 |
nah. you plug the factory harness in there if it fits. otherwise you'll need a harness adapter.
12-18-2010, 08:20 PM | #6 |
i think its supposed to go into a relay and connect to the battery it has a + and a - symbol on the other side
12-18-2010, 08:22 PM | #7 |
did anyone get the hid kit for the fogs from garm i check to see if it was in the DIY section but it wasnt
Similar Threads | ||||
auto depot headlights + HID's? | thebarber | Cosmetic Modifications (Exterior/Interior) | 42 | 01-19-2012 05:56 PM |
installed some 3000k HID's | thebarber | Photo-Video-Media Gallery | 17 | 01-22-2010 09:45 AM |
Where is my DRL Module......? Help With HID's | The Architect | DIY / Maintenance / Service | 6 | 05-20-2009 10:21 AM |
DRL and HID's? | dimsum69 | Cosmetic Modifications (Exterior/Interior) | 5 | 01-12-2009 03:30 PM |
NEW HIDS 10000k!!!!!! | elsteverino889 | Cosmetic Modifications (Exterior/Interior) | 69 | 01-26-2007 12:12 PM |
