Old 11-18-2010, 12:03 AM   #1
Clowncar
Clowncar's Avatar
Drives: 2007 3-Door, 5-Spd
Fog light install using factory wiring
A few years ago I had a post on the method that I used to install fog lights without having to go through the firewall. The Yaris' are "pre-wired" to accept aftermarket fog light kits. Here is a zip file attached that contains a doc file of the procedure.
Clowncar is offline   Reply With Quote
Old 02-21-2019, 02:16 PM   #2
soldiersvejk
Drives: 2009 Toyota Yaris Sedan
Smile
Can't believe I find it!
I tried to install an after market fog lamp kit, but during the process I was more and more suspicious that my 09 yairs sedan was actually pre-wired for fog lamps.
Thank you very much!
soldiersvejk is offline   Reply With Quote
Old 02-21-2019, 07:03 PM   #3
zoidberg444
zoidberg444's Avatar
I have a made in Japan Yaris for the Euro market. It's a bit more complicated with us. We have some of the wiring for the fog lamps. We already have the fog lamp relay for a rear fog lamp (an extra bright red bulb so drivers can see us) as standard. But no front lamps. The pins in the engine bay fuse box are not connected to anything on either end.
I would have to piggy back current from the switched side of the fog light relay and go through the bulkhead in order to power my front fog lamps. I have a cheap harness and the lamps from a scrapyard. I just haven't got round to doing it yet.
UK to Nordkapp in a Yaris
aftermarket, factory wiring, fog, foglights
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Rear fog light for US '08 3Door Yaris (stick shift9 Stefan DIY / Maintenance / Service 21 04-21-2010 04:30 PM
My new fog light ezlove0710 DIY / Maintenance / Service 1 10-01-2009 04:10 PM
Sorry! Another fog light question. Jrilla DIY / Maintenance / Service 4 08-23-2009 02:25 PM
