Old 11-22-2018, 01:35 AM   #1
YarisSedan420
Drives: 2007 Toyota Yaris Sedan 1.5
What is the name of this hose?
I can not find the name of this hose for anything and I'm trying to figure out how much it's gonna cost me to order it. Thanks in advance!
YarisSedan420 is offline   Reply With Quote
Old 11-22-2018, 08:45 AM   #2
Check out Rock Auto.
https://www.rockauto.com/en/catalog/...rant+hose,6900
Old 11-23-2018, 03:24 PM   #3
YarisSedan420
I noticed that link was for AC refrigerant hoses. Which it appears that is in fact what the hose is. But here is my problem...
I'm leaking engine coolant. After I noticed it and the area dried up a bit I ran the car for a while to get the coolant flowing and the only place I could find any signs of wetness is from this hose where the metal meets the rubber. But if this hose is the AC Compressor to Evap hose, it wouldn't have engine coolant running through it, right?? it's directly at the lowest point of this hose (where liquid would start dripping from it rather than running along it) where I first noticed the puddle of coolant on the plastic under the motor.
Old 11-23-2018, 03:35 PM   #4
tmontague
tmontague's Avatar
Likely your water pump leaking onto the hose. The only thing around there that will leak coolant is the water pump, or a lower rad hose. If your hose checks out then it is your water pump
Old 12-03-2018, 01:32 PM   #5
Mike Dexter
Drives: '10 Hatchback
Are you sure its coolant, and not oil from the AC compressor? That stuff is sometimes bright green, and the compressor is also above that plastic shield.
Mike Dexter is offline   Reply With Quote
2001 Echo - CAI Air Box Hose ITA Performance Modifications 0 05-25-2017 11:46 AM
HVAC dripping water when AC on. Drain hose is NOT clogged. kustomrtr DIY / Maintenance / Service 3 09-07-2014 09:45 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
vacuum hose / heater hose size cali yaris Performance Modifications 12 05-17-2013 09:58 PM
