Old 05-30-2019, 03:00 PM   #73
sven337
Drives: Yaris
It's a buck module, not a linear power supply, you can adjust it without a load.
The VFD is only useful for testing, if you're doing my repair you don't need it you just need to set up the buck module for about 1.5V.
Removing the SMT components is easy. Chisel tip, 30W or more, add a bunch of leaded solder, heat up like crazy (you don't care you're removing everything) and the transistors will slide right off.
As for the VFD socket, I actually soldered the output lead of the buck module to the base of the VFD connector. Not soldering sounded like a potential issue with vibration.
sven337 is offline   Reply With Quote
Old 06-09-2019, 03:41 PM   #74
adsb
Drives: Yaris 1.0 t3
Right hand drive model repaired, thanks to sven337 for the instructions.
Photos of MP1584EN device, testing with DMM to obtain correct output of 1.5v, more photos of the existing transistors and after removal (a few pads came off in the process) , close ups of buck regulator in situ and wiring to pin 1 of VFD connector.
I disconnected the battery negative terminal before removing cluster.
Used a 12v 1.2ah battery from commercial intruder alarm panel as poor mans lab psu for testing.
I noted that there were 5 transistors not 6 for my model.
That ribbon cable is a right PITA to get back in to the slot and close the latch on the connector !
Sorry if the photos are in the incorrect order.
Thanks again sven337 !
adsb is offline   Reply With Quote
Old 06-29-2019, 09:38 AM   #75
sven337
Drives: Yaris
Thank you for the excellent pictures that will, no doubt, help people implement the fix.
Old 08-13-2019, 10:40 AM   #76
NOLF
Drives: Yaris 1.0
Sorry but i can find dashboard pinout, can you post it for me. I can't test me dash, i don't no where is positive and negative.
NOLF is offline   Reply With Quote
Old 08-14-2019, 05:33 PM   #77
sven337
Drives: Yaris
https://perso.aquilenet.fr/~sven337/...test_setup.jpg
+12V top right
GND bottom left
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 08:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 05:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 09:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 07:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-09-2009 11:33 PM
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
