Old 12-30-2018, 12:59 PM   #1
mik23
Drives: yaris 2005
Yaris High Beam Issue Only one headlight is working
Hi All
Just experinced s strange thing.
Normal headlight on then tried to put on high beam then only one of the headlight is working.
Under normal conditions both headlight works.
Left low beam req replacement will do in next couple of week.
But I wasnt expecting only one headlight working in high beam
Any ideas
Thanks
mik23 is offline   Reply With Quote
Old 12-30-2018, 02:06 PM   #2
High beam filament is burnt out.
Sent from my EML-L09 using Tapatalk
Old 12-30-2018, 02:08 PM   #3
mik23
Drives: yaris 2005
Thanks where is that howncan i replace that
Sent from my SM-G930F using Tapatalk
Old 12-30-2018, 02:10 PM   #4
The lightbulb itself is dual filament. One filament for low and one for high beam. You need to replace the bulb.
Old 12-30-2018, 02:18 PM   #5
mik23
Drives: yaris 2005
Hi
I have looked again
I am confused it seems the headlights are both working but one is not in high beam.
This bulb is H4
The other issue is parking light which is seperate bulb. W5W 12V wedge base type.
Thanks
Old 12-30-2018, 02:19 PM   #6
mik23
Drives: yaris 2005
Just to clarify
1 both work in normal headlight.
2 dipped position only one working
3 when on high beam one headlight is not working
Old 12-30-2018, 02:25 PM   #7
Swap your bulbs from side to side. If bulb is faulty, what you are experiencing will change sides.
Old 12-30-2018, 05:21 PM   #8
IllusionX
Drives: 07 Yaris Sedan Aero
That teardrop light is not parking light. If it is, then someone has messed up with your wiring
Sent from my CLT-L04 using Tapatalk
Old 12-30-2018, 06:23 PM   #9
mik23
Drives: yaris 2005
Thats strange we use term parking lights for these low beam front headlights here in uk.
Can u clarify pls
Thanks
Old 12-30-2018, 06:43 PM   #10
IllusionX
That tear drop that uses a wedge type bulb is not your low beam/parking light. They are supposed to be your blinkers.
The H4 bulbs are supposed to do both your normal driving light (low beam) and high beam.
Old 12-30-2018, 06:53 PM   #11
mik23
Drives: yaris 2005
Got it cheers will replace the h4 swap first...
Thanks Gents
Wiper and High Beam Issues seymour201 DIY / Maintenance / Service 4 10-02-2015 06:39 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
HELP! I detailed my interior, and now having a headlight issue! Astroman DIY / Maintenance / Service 4 06-08-2010 06:51 PM
