Old 11-05-2011, 02:12 PM   #1
Just a Wee exhaust leak
Finally got around to addressing a leak which became apparant last spring. As part of winterizing, I swap out my Tanabe for the stock exhaust. Leak became really obvious with the noise of the Tanabe removed, so today I got on it.
Was totally flabbergasted at how little of the original header/down pipe gasket remained. With new one in, I'd forgotten how pathetically quiet these cars really run.
Old 11-07-2011, 06:33 PM   #2
viggen
Drives: echo hatch 3d and RAV4
Oddly enough I had the very same gasket replaced today.
It looked just a touch better, but I could hear the leak on a cold morning.
Easy and efficient fix:-)
viggen is offline   Reply With Quote
Old 11-07-2011, 09:07 PM   #3
i had to do the same on my vibe this summer....its typical
my yaris is back to stock exhaust and i think you summed up the sound nicely, wee
Old 11-08-2011, 08:32 AM   #4
vten
weeyari, where did you get the new gasket and the bolts ? I think I need to replace mine too
thanks
Old 11-08-2011, 08:39 AM   #5
thanks
im guessing the toyota dealer...
Old 11-08-2011, 08:50 AM   #6
Yeah, dealer.
NAPA didn't carry the stuff, and I didn't feel like wasting time searching for cheaper alternatives. I'd be interested in what American dealerships charge.
Gasket $49.28
Bolts $8.28 each
BTW, new bolts are 14mm. One of the old ones took a 13mm nicely. The other one I had to hammer on a 12mm to get it out.
Old 11-08-2011, 09:48 AM   #7
vten
these parts are for between the down pipe and the rear muffler right ? I was wondering if I can use the same parts for the header to the front of the down pipe section ...
I have the weapon R header, nitto midpipe and nitto muffler.... I smell the gas fumes getting stronger lately , and it sounds prrrp prrrp prrrp prrrp ( hope it right ...lol) from between the header and the front midpipe
Old 11-08-2011, 09:53 AM   #8
No, these are for the header to down pipe connection.
Your symptoms do indicate that you have the same blown gasket as I had.
Old 11-08-2011, 10:04 AM   #9
vten
sweet!! thanks weeyari ..
will call toyota stealer for these parts soon
Old 09-02-2015, 06:24 AM   #10
John Lenin
Drives: 2009 Toyota Yaris 3-Dr HB Auto
Have ordered these parts from wrenchmonkey.ca (gasket and spring bolt kit) for my '09 Yaris ... $34.00CDN ($11.00 of which is shipping) ... should be here in a week. Had the same problem with an Echo I owned several years ago ... muffler shop charged me twice as much for parts as I paid at wrenchmonkey.
Exhaust leak has gotten worse daily since I became aware of it last weekend ... will it be OK to drive until parts come in and can fix the leak in a weeks time?
John Lenin is offline   Reply With Quote
Old 09-02-2015, 07:27 AM   #11
IllusionX
Drives: 07 Yaris Sedan Aero
Wow, why are you reviving such an old thread?
Yes it will be OK to drive with an exhaust leak, though you might smell exhaust gas in the cabin
Sent from my A0001 using Tapatalk
Old 09-02-2015, 11:17 AM   #12
shepd
Drives: 2007 Yaris 5 door RS
Don't drive forever with the exhaust leak, though. Get it fixed when you can. Remember that exhaust gases are toxic so if you're planning on idling for a long time, windows open and fresh air running!
Also, with exhaust gas slipping past the front gasket your car you will eventually throw a code for poor catalytic converter performance, which if you have a smog test means you will fail. Fortunately, the important (front) sensor is just before the gasket (engine side) so you shouldn't get bad mpg or risk damaging the catalytic converter.
shepd is offline   Reply With Quote
Old 09-02-2015, 03:24 PM   #13
Nothing wrong with a thread revival, especially when it is one of mine
Tags
donut, dounut, exhaust gasket
Newbie with an exhaust leak on his '06 Yaris ToYarta DIY / Maintenance / Service 49 01-03-2019 12:50 PM
FS: Megan Racing Exhaust n Header. Sabretooth Items for Sale by private party 6 05-17-2009 05:04 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
GReddy prototype = Free Exhaust! Chris_Lum California 30 02-27-2007 10:13 PM
