Old 05-06-2016, 07:18 AM   #1
mik23
Drives: yaris 2005
Air Conditioning Problem
Gents
Problem : AC is not blowing cold air
AC lights on
Blower fan working setting 1 2 3 4 all different speed
Visually checked compressor at the belt / pulleys
Cabin filtre replaced (blower motor is under this)
Can anyone suggest any other thing I need to check
mik23 is offline   Reply With Quote
Old 05-06-2016, 07:32 AM   #2
Probably best to take it to the shop. You've either got a leak and the system is out of or low on refrigerant, or the compressor is shot.
Old 05-06-2016, 09:52 AM   #3
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
You've either got a leak and the system is out of or low on refrigerant..
My money is on this one
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 05-06-2016, 09:58 AM   #4
mik23
Drives: yaris 2005
I think i am in agreement with u its low on refrigerant.
Old 05-06-2016, 10:09 AM   #5
Could also be, but probably not, a failure in the coolant line pressure sensor. If this sensor has failed, or is sending a low pressure signal, the compressor will not kick in.
Old 05-06-2016, 10:16 AM   #6
mik23
Drives: yaris 2005
Can u pls upload a pic where it is how can i check
Old 05-07-2016, 07:39 AM   #7
mik23
Drives: yaris 2005
Update
Recharge the gas and its now ok.
Thanks All
Old 05-07-2016, 08:23 AM   #8
ex-x-fire
Where's it leaking from?
Old 05-07-2016, 09:00 AM   #9
mik23
Drives: yaris 2005
Mech said no leaks
Old 05-07-2016, 10:47 AM   #10
bronsin
bronsin's Avatar
Uh oh you might have the problem all over again if the lack of fluid was because of a leak.
Old 05-07-2016, 10:48 AM   #11
mik23
Drives: yaris 2005
All over ?
Old 05-07-2016, 10:51 AM   #12
mik23
Drives: yaris 2005
Car req recharge every 2-3 year
Old 05-07-2016, 12:30 PM   #13
bronsin
bronsin's Avatar
Really? My car is 7 years old and my wife's is nearly 12 years old and the ac works and has never been recharged.
Old 05-07-2016, 12:51 PM   #14
mik23
Drives: yaris 2005
Old 05-07-2016, 12:54 PM   #15
mik23
Drives: yaris 2005
Air Conditioning Re-Gas
It is recommended that you should recharge your air conditioning system every 2 years with gas and lubricant, in order to keep it running efficiently. This is not included as part of a routine car service and so it can often be overlooked. If your car is more than 2 years old it is more than likely due a re-gas.
This service ensures that your air conditioning system is working efficiently by testing the gas pressure to see if it has dropped. A drop in gas pressure will result in a loss of cooling efficiency which will make your engine work harder and in turn use more fuel.
Due to it's dehumidifying properties, when operating fully efficiently, your air conditioning system will also de-mist your windscreen more rapidly in cold weather.
Login & Quick Reply
Old 05-07-2016, 12:55 PM   #16
mik23
Drives: yaris 2005
Now thats my understanding
Old 05-07-2016, 12:55 PM   #17
mik23
Drives: yaris 2005
Happy to correct myself
Old 05-07-2016, 05:56 PM   #18
ex-x-fire
Originally Posted by mik23 View Post
Mech said no leaks
Yes, you have a leak. Hopefully he put some dye in it to find it with a UV light. They even have leak detectors that can smell where the leak is.
Need help troubleshooting air conditioning davislau DIY / Maintenance / Service 7 07-15-2015 10:54 AM
air circulation fan problem tomdf DIY / Maintenance / Service 8 12-10-2012 06:53 AM
Air conditioning Blower satdan DIY / Maintenance / Service 1 09-13-2012 02:13 PM
max air conditioning button Idahotom General Yaris / Vitz Discussion 0 07-06-2011 09:41 PM
air conditioning markpeppie General Yaris / Vitz Discussion 34 06-20-2006 01:17 PM
