Old 08-17-2015, 12:09 AM   #1
vitzbitz69
Drives: White 2010 Yaris
Fog light issue.
I know, another fog light post. But I recently replaced my fog light bulbs with the Nokya yellow bulbs and they turned on fine on install, drove around for a bit and noticed they were not on when I pulled up to my drive way. And now they will not turn on at all. So I checked the bulbs and they're fine. I took the relay out that I received in the microimage fog light kit that I bought and popped it back in and they turned back on for a bit. Next day they won't turn on again. Any ideas? Thanks.
vitzbitz69 is offline   Reply With Quote
Old 08-17-2015, 05:50 AM   #2
It is likely that the relay is failing. Try bypassing it by jumping the top two terminals of the relay socket with a paper clip or piece of wire and see if they then come on. The top two are the horizontal ones which are stacked one above the other.
Old 08-17-2015, 08:26 AM   #3
vitzbitz69
By "jumping" you mean?
Old 08-17-2015, 06:54 PM   #4
shepd
Drives: 2007 Yaris 5 door RS
Jumping means inserting a piece of wire between the contacts.
shepd is offline   Reply With Quote
Old 08-17-2015, 11:19 PM   #5
valchrist90731
Drives: 2007 toyota yaris sedan
Did you figure it out?
If you put bud connectors on the wires. They will rust out and no more fog light. Cut the bud connectors, solder, then use shrink tube for good connection.
Im the third owner of this yaris that has 60000 miles for a 2007. So who ever did the external wiring for the fogs did a horrible job. Easy fix.
Do it right the first time.
valchrist90731 is offline   Reply With Quote
Old 08-18-2015, 12:04 AM   #6
vitzbitz69
I haven't had the time to do it yet. Been working but this weekend I am doing a bunch of stuff on my yarii so I'll definitely try those things. Thanks for the input guys.
Old 08-18-2015, 02:01 AM   #7
bairjo
Relay....was my first thought when i read this earleir. Seeing that "the Master," CTScott already leaned toward this...well almost assures that it is the relay...not 100% sure...but a pretty informed opinion his is.
bairjo is offline   Reply With Quote
Ebay Fog Light Rant CTScott DIY / Maintenance / Service 65 06-13-2022 12:10 PM
WTB: Fog light switch from the Micro Image fog light kit swidd Willing to Buy by private party 23 05-16-2013 08:37 PM
Not sure what section .. So question on fog light housing that was .... *PICS* SoCalSTEVE DIY / Maintenance / Service 3 05-01-2013 07:46 AM
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
Fog Light Misalignment and Moisture DjT General Yaris / Vitz Discussion 3 04-27-2009 03:24 PM
