Old 02-14-2006, 10:18 AM   #1
krakkhenz
Drives: Toyota Yaris
What type of octane I should use???
Im a little confused about this, my car seller told me that I should use 95 octane gas, but the manual says I should use 91
What are the difference between 91 and 95???
My yaris got a 1.3 engine.
krakkhenz is offline   Reply With Quote
Old 02-14-2006, 11:22 AM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I'd go with what the manual says.
The difference between octanes is how much pressure is required to ignite the fuel. The higher the rating the harder it is to ignite the fuel.
Old 02-15-2006, 09:11 AM   #3
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
I thought the car (Yaris) can run on 87?
GabL is offline   Reply With Quote
Old 02-15-2006, 10:34 AM   #4
why?
why?'s Avatar
Drives: Yaris LB
The rest of the world measures octane differently then we do in North America.
Old 02-15-2006, 04:55 PM   #5
GabL
I want JDM bumpers!
GabL's Avatar
oh, didn't saw the OP was from Panama...
Old 02-15-2006, 08:15 PM   #6
as400g33k
as400g33k's Avatar
Drives: 05 YRS Silver Lining Metallic
the yaris is rated to run at 91 but can also accept higher octane. most people would claim a performance boost when using higher octane. while some would even claim better fuel efficiency with higher octane.
we use 91, as it is cheaper than 95, 98 or 100 octane. :)
as400g33k is offline   Reply With Quote
Old 02-15-2006, 09:52 PM   #7
GabL
I want JDM bumpers!
GabL's Avatar
100 octane!! It's gonna burn like
Old 02-15-2006, 11:09 PM   #8
swng
swng's Avatar
Drives: 06 3-dr auto RS
Don't worry friend, the higher is the octane no., the harder it is for the fuel to burn.
swng is offline   Reply With Quote
Old 02-16-2006, 07:31 AM   #9
ToTo
ToTo's Avatar
Drives: Toyota Yaris T SPORT
Hi guys! So the harder for the fuel to burn is not good in the long run? I have a TS model, I currently use 95 octane... What if I were to use 98 or 100 octane fuel, what would change? Would the car run better or would I feel a bit more power or torque, or is all this just BS?
ToTo is offline   Reply With Quote
Old 02-16-2006, 08:19 AM   #10
GabL
I want JDM bumpers!
GabL's Avatar
Use what is recommanded in your user manual...
http://autorepair.about.com/od/engin...hoctanegas.htm
Old 02-16-2006, 10:18 AM   #11
why?
why?'s Avatar
Drives: Yaris LB
Unless you are experiencing rough running or misfires, then odds are the car would not run smoother.
However there prolly would be a slight increase in tourque and fuel mileage with higher octane fuel.
With fuel that is harder to burn, the spark timing can be set better, and the detonation can be more exact. This also means that the computer can use a more exact air/fuel ratio.
The thing is if your vehicle is stock, it might not make a difference that you could actually feel in everyday driving. The only way you could tell is by using a dyno, and that gets really expensive.
Old 02-16-2006, 11:27 AM   #12
krakkhenz
ummm... thanx for your replies, im using 95 octanes since the first day, but im gonna try with 91 and set the trip B for the next refuel.
Old 02-16-2006, 08:19 PM   #13
swng
swng's Avatar
Actually, you and why? know a lot!
Old 02-17-2006, 04:07 AM   #14
ToTo
ToTo's Avatar
Thanks guys! I have no problems at all with the car, it runs great! I just didn't know the low down on the higher octane stuff... I guess I'll just stick with Shell 95 octane fuel. Oh yeah, Shell has a V-POWER 95 octane fuel as well besides the V-POWER RACING 100 octane fuel, do any of you have opinions or experiences on the V-POWER 95 octane fuel? Supposedly it contains some additives or something extra that the regular 95 doesn't...
Old 02-17-2006, 08:40 AM   #15
why?
why?'s Avatar
Drives: Yaris LB
No experience with it, I don't remember seeing anything like that marketed over here.
But additives usually do something interesting, so you could give it a try and see what it does, but since it is the same octane, it prolly will only do things like clean the engine, I don't think it would make a difference in the power output of the vehicle.
Old 02-17-2006, 03:34 PM   #16
ToTo
ToTo's Avatar
Yeah, this is also what I heard, that additives really do something to the engine which is not really harmful, but rather good for the engine since it cleans it somehow! I might give it a try though...
Old 02-18-2006, 06:13 PM   #17
yariman
Speed Wrenchin'
yariman's Avatar
Drives: 2006 Yaris 3 door, Bayou Blue
Additives help clean the fuel system etc. but you are only wasting money using higher octane thinking that the Yaris will benefit from it. As I mentioned in another post, unless you change your prom fuel/timing maps you can't advance your timing or add more fuel to even get detonation.
Quench my thirst with gasoline
yariman is offline   Reply With Quote
Old 02-19-2006, 03:34 AM   #18
ToTo
ToTo's Avatar
I got ya Yariman, thanks for the input!
