Old 09-23-2017, 08:13 AM   #1
colblu44
Bruce
Drives: 2008 hatchback and sedan
Question Turn signal won't shut off on its own
My right turn signal won't self cancel. Can I fix this myself? Should I replace the whole unit? Any instructions posted anywhere?
colblu44 is offline   Reply With Quote
Old 10-09-2017, 08:47 PM   #2
xdarkxfirex
Drives: 2015 yaris le
I would check to see if there is a flasher on this car. It could be the problem sometimes. Replacing the switch requires you to mess around with the steering wheel. Is this a constant problem or intermittent?
xdarkxfirex is offline   Reply With Quote
Turn signal auto-shutoff not working spookybathtub DIY / Maintenance / Service 5 09-23-2017 07:55 AM
No Turn Signal or Reverse light ezhacker1 DIY / Maintenance / Service 2 05-07-2013 07:21 PM
Turn signal audible alert paultyler_82 Performance Modifications 7 10-01-2006 10:21 AM
Turn signal bulbs casterqc Cosmetic Modifications (Exterior/Interior) 2 07-15-2006 07:44 PM
