11-13-2010, 01:31 AM | #1 |
It's cold in Wisconsin...
Drives: 2008 and 2009 Yaris Sedans Join Date: Nov 2009
I want HID's....
Not to start a big huge flame session, but just thought I'd ask.
I currently have Sylvania Silver Star Ultra's in my 08 and 09 sedans. Great bulbs but the life on them stinks =( If I get HID's from garm do I run the risk of getting pulled over for non OEM equipment? i've heard that some of the more "blue" colored lights in stock housing causes light to scatter / etc. Would I need to do an HID retrofit to make them compliant? please let me know thanks.
2008 Toyota Yaris - Polar White / 80K (over 20k a year in miles) 2009 Toyota Yaris - Flint Mica / 24K (PAID OFF!) |
11-13-2010, 02:23 AM | #2 |
Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
I say either get the retro-fit like I did, or fab up something that blocks the bottom of the plug and play HID kits. I've had both, and I'll tell you know, you'll blind the crap out of people with the PNP kits. People will flip you off too. The reason why the light on PNP kits are scattered is because it's being reflected from the bottom of the bowl. If you look at the 2005 Escalades, they do not have projectors, yet have HIDs. However, if you look at one with the HIDs on, you'll notice that the bottom of the reflector bowl is not being illuminated, and not scattering the light upward.
11-13-2010, 02:24 AM | #3 |
It would be even better if you do a legit/real retro-fit too. :)
11-13-2010, 09:00 AM | #4 |
Drives: 2009 3dr LB Manual Join Date: Mar 2010
The projector retrofit is the best option for HID's. You'll get the best light output, cops will leave you alone (as long as you don't go a stupid color), and other drivers will thank you. I did a projector retrofit on my LB (not the one Garm sells) and it's great. I get compliments, and after a couple months, not a single person has flashed me or flipped me off. Spend a bit more money and time and do it right!
11-13-2010, 08:19 PM | #5 |
Drives: 2008 yaris, stripped, red Join Date: Jan 2009
get them....support our vendors...microimageonline.com they got a bi-xenon set for 90 bux
11-15-2010, 08:03 PM | #6 | |
The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
besides if you do the projectors itll make your car that much more badass instead of a halfass hack job.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
11-16-2010, 11:56 AM | #7 |
just get 4300k hid's
you need to re-aim the lights down when you go HID in reflector housings...
11-16-2010, 03:19 PM | #8 |
http://shop.microimageonline.com/H4-...its-H4-HID.htm
The H4 bi-xenon kits @ 8K or is ice white too over the top without doing a retrofit...
11-16-2010, 03:21 PM | #9 |
^ imo, that's way too blue, even with a retrofit. I think my 6000k is still too blue. I really suggest going with 4300k bulbs if you can.
11-17-2010, 11:31 PM | #10 |
Heart Up! Vitz
To the OP of this thread,
I have been running Garm's Plug n Play HIDs for about a year now.... They are awesome...they dont have a glare as much as other cheap HID brands out there. But as Kaotic has said, you need to plug up this slit in the HID bulb holder frame. I plugged mine up and when i directly look at it, i can see 90% of the light shooting on the upper half of the headlight.."no glare in your face" factor. I simply took some pieces of aluminum foil and pretty much stuck them at that hole and voila~ perfect and no flipping off...driven behind cops at night. Just make sure you aim your headlights a bit downwards, thats all.... |
11-18-2010, 10:41 AM | #11 | |
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
8K is too blue. Like the other poster above said, optimal color temp range is 4300-5500K. The closest the color is to natural light, the better. -SAV
Georgia Bulldogs! '09 Yaris LB 5MT Sold. |
11-18-2010, 04:50 PM | #12 |
Heart Up! Vitz
The bandaid will tear..lol.
It's not the best solution to the OEM JDM headlights that use HIDs from the factory or projectors....but it does eliminate the blinding problem, that I can say. |
Similar Threads | ||||
auto depot headlights + HID's? | thebarber | Cosmetic Modifications (Exterior/Interior) | 42 | 01-19-2012 05:56 PM |
installed some 3000k HID's | thebarber | Photo-Video-Media Gallery | 17 | 01-22-2010 09:45 AM |
Where is my DRL Module......? Help With HID's | The Architect | DIY / Maintenance / Service | 6 | 05-20-2009 10:21 AM |
DRL and HID's? | dimsum69 | Cosmetic Modifications (Exterior/Interior) | 5 | 01-12-2009 03:30 PM |
NEW HIDS 10000k!!!!!! | elsteverino889 | Cosmetic Modifications (Exterior/Interior) | 69 | 01-26-2007 12:12 PM |
