Old 11-09-2017, 06:41 PM   #1
CT_11_Blue_HB
Drives: 2011 Yaris 5dr HB Auto
P1349 Code - What To Try Next
First, thanks to all the forum members for all the info they share. I've been a registered lurker for a few years and have learned a lot from all the great posts here.
Looking for some help on diagnosing and fixing P1349 Code.
Car is 2002 Echo with ~280,000 miles.
Recently got P1349. Checked oil and it was low. Took about half a quart to bring it up to mid point on dip stick range. Reset code.
About 1 week, ~ 250 miles later, P1349 again. Realized it was about 2500 miles since last oil change, changed oil, reset code.
About another week, another 100 miles, P1349 again.
Decided to try what I thought would be next easiest thing and replaced OCV and VVTi filter. Ended up breaking OCV in block, but was able to extract with a 7/16" tap. Reset code. A day later, ~50 miles, P1349 again.
In each case, CEL comes on at low engine RPM. Next time I reset code, I will capture and write down freeze frame data from code reader.
Trying to decide what the next step is before considering replacing the cam timing assembly (which seems like a PITA).
Any thoughts?
Since this is a daily driver, found a 2011 Gray HB Yaris with 48K miles that I pick up tomorrow - just in case Echo is on last legs. Will be a stablemate to current 2011 Blue HB Yaris.
Thanks for your ideas!
CT_11_Blue_HB is offline   Reply With Quote
Old 12-21-2017, 01:21 PM   #2
CT_11_Blue_HB
Finally got around to looking at this again....
P1349 reappears as pending almost immediately after clearing codes. I've cleared codes a couple dozen times and P1349 keeps reappearing. There are no noticeable drivability issues (idles fines, no hesitation). Thinking the next thing to try is replace VVTi cam assembly. Dealer wants ~$900 to replace ($300 parts, $600 labor). With 280K miles, not sure it is worth it.
Another option is to replace cam assembly myself. OEM part from ToyotaPartsDeal is $195. Can camshaft be removed without removing timing chain cover? Seems like if I could release timing chain tension and ensure chain stays on crankshaft gear (not sure how likely this is) this would be much easier than removing cover which requires removing engine mount.
Has anyone removed intake cam without removing timing chain cover? If so, any guidance on how to do it and any pitfalls to watch out for?
Old 12-21-2017, 01:51 PM   #3
Dodge Aries K
My Yaris is a taxi
Drives: 5 Yaris Hatchbacks
It might be the vvti actuator which is mounted externally on the cylinder head behind the alternator.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 12-21-2017, 02:22 PM   #4
tmontague
tmontague's Avatar
If the dealer did a proper diagnosis and is sure it's the cam assembly then I'd recommend you do it yourself and it should fix the issue. Or have them do it but it will cost you.
You do not need to remove the timing cover to remove either cam shafts. Iirc it is stated how to remove tension in the chain in the repair manual.
When I did it a while back I believe I had to turn the engine counter clockwise which pushed the tensioner back and then you use a small Allen key and insert it into the tensioner to hold the tensioner back. You access this from a little "window" you remove to put the Allen key into the tensioner. Then I ziptied the chain into the other cam gear while I removed the other so the chain didn't fall down into the cover assembly.
Few things to look out for:
Make sure your timing marks are all set prior to reassembling everything
Hand crank the engine once everything is reassembled to ensure it feels right and you aren't throwing a valve into a piston.
Don't let the chain fall down into the timing cover assembly or else you'll be having a bad day.
Get a hold of the repair manual (i used the '07 and it worked fine for my '02 echo) so you know what you're dealing with before starting
I like to drive a slow car fast...
Old 12-21-2017, 05:39 PM   #5
CT_11_Blue_HB
Thanks Dodge Aries K! I was hoping it was only the actuator, but after replacing both the VVTi actuator and the filter (both with Toyota OEM parts), problem persisted.
tmontague,
Thanks for pointing out timing chain cover does not have to be removed and suggesting a look at the service manual. Section on setting valve clearance shows how to remove camshafts with timing chain cover still on. Looks straightforward. Do you know if there is any risk of chain coming off of crank shaft gear? Online photos of that area show a semi-circular lip that appears to be designed to keep that from happening. Would be nice if I could get aware with only removing intake cam.
I haven't had dealer confirm it is vvti actuator. They charge ~$80 to hook up the Techstream and give diagnosis. Seems like the way to go to confirm its the actuator.
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 08:03 AM
Error code P1349 Liloolil DIY / Maintenance / Service 18 06-15-2015 05:26 PM
Our Nissan Leaf review Thirty-Nine Off-topic / Other Cars / Everything else Discussions 41 12-17-2013 10:13 PM
full tank japle Fuel Economy Forum 15 12-10-2013 12:05 PM
Sponsors List RogueYaris Sponsors Classifieds Area 14 01-05-2013 11:23 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
