11-07-2018, 11:52 PM | #1 |
Drives: 2009 Yaris Join Date: Mar 2011
2009 Yaris erratic idle
Occasionally my Yaris seems to want to low idle around 500. Ideas?
11-08-2018, 08:23 AM | #2 |
Drives: 2007 2-door hatchback Join Date: Jul 2016
Toyota Tachometer
What is measuring this rpm? Just the arm arm on the OEM dial tachometer in the instrument cluster? (I don't have tach option, so don't know if there is a digital readout.)
Is car auto or manual? In what gear positions is 500 rpm idle? |
11-08-2018, 08:25 AM | #3 |
Drives: No longer own a yaris :( Join Date: Mar 2012
Do you have a CEL?
11-11-2018, 05:27 PM | #4 |
Analog tach goes down and I can feel the engine dropping rpm. It’s a stick. Notice it stopped in neutral.
11-11-2018, 05:47 PM | #5 |
Drives: 2010 3dr LB Join Date: Sep 2010
I have a 2010, 140,000 mile, manual trans, that does the same, has done it since new. Bill C
11-12-2018, 08:23 AM | #6 |
Normal is only 600 rpm. Feels slow compared to 91 manual 1600 Corolla 750 spec rpm.
Can see 100 rpm on gauge that swings to? 8000? |
11-13-2018, 08:32 AM | #7 |
I can say that the idle in my 08 manual hatch has always been....asynchronous? It tends to drop and then rise every few seconds, but never low enough to where it feels like it's going to stall. I drove another yaris a few years ago that did the same thing.
11-13-2018, 08:38 PM | #8 |
Toyota Yaris low hunting erratic idle Corolla timing
The 1991 Corolla 4A-FE has a hunting spark advance at idle...you can hear it in the stock intake. To check timing, you place an electrical shunt somewhere so the idle timing stays in one place. Mind of Toyota.
(Consistent w/ factory shop manual. I think hunting can be a way to optimize some tuning parameter(s).) I think my Yaris idle is pretty steady. Cooling fan and/or A/C cycling, and maybe alternator voltage regulation, could cause idle fluctuation. |
11-14-2018, 05:59 AM | #9 |
Drives: 08 Sedan Join Date: Oct 2008
11-14-2018, 01:49 PM | #10 |
11-14-2018, 02:35 PM | #11 |
By the needle, warm engine, mine idles 500 rpm on the nose.
11-15-2018, 12:50 PM | #12 |
Toyota Yaris idle speed
Using pin 8 (or 9?) on Hal's 16 pin OBD connector, and a ground to a mid level digital multimeter set on "frequency," my 2007 manual Yaris warmed up would, and may still, idle at 600 rpm...exactly 600.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
FS: 2009 Yaris 3dr left-overs | jecurtin3 | Items for Sale by private party | 12 | 08-09-2013 02:57 AM |
Just bought: 2009 Yaris Sedan | Prometheus Bound | New YARIS Purchase Forum | 2 | 05-11-2013 11:45 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
