Old 10-22-2018, 09:48 PM   #1
bluefever00
Drives: 2008 Sedan
Oxygen sensor issues
My dad has a 08 Yaris sedan. He recently had the exhaust manifold replaced. The first oxygen sensor kept setting off the check engine light immediately. He had it replaced with an ultra-power brand one from rockauto. Immediately after it started feeling like it was cutting out almost, but the check engine light didn't come on. They thought it might be the secondary sensor being older that it might be slower. That one was replaced with an ultra- power brand one. It cuts out somewhat less but the check engine light still hasn't come on. The car never acted like this before, it had an exhaust leak, but no check engine light and plenty of power for a car like it. Now it's kind of a dog under load and cuts out. Any suggestions?
bluefever00 is offline   Reply With Quote
Old 10-23-2018, 02:16 AM   #2
scylla
Drives: 2015 Yaris L
Depending how long that has been going on, it could just be a ecu re-learning process. After cleaning my MAF sensor and throttle body with battery unhooked, my engine ran rough for a bit before it settled down.
After you changed your O2 sensors did you remove the ground off of the battery to clear the computer?
scylla is offline   Reply With Quote
Old 10-23-2018, 09:55 AM   #3
bluefever00
Drives: 2008 Sedan
Yes, the battery ground was removed for about 15 minutes. It has been over a month.
Old 10-23-2018, 07:00 PM   #4
benoityip
Drives: Corolla 1.8
Do you change the exhaust manifold gasket?
benoityip is offline   Reply With Quote
Fault code P2196 Oxygen sensor? Saphe DIY / Maintenance / Service 9 12-16-2021 08:07 AM
Oxygen sensor Spellino DIY / Maintenance / Service 6 11-08-2017 09:56 AM
1999 yaris oxygen sensors jblomster DIY / Maintenance / Service 6 08-16-2015 07:36 AM
Signal wire on Oxygen sensor??? d.one DIY / Maintenance / Service 8 04-25-2013 12:28 PM
need quick help to find oxygen sensor mariann DIY / Maintenance / Service 11 10-02-2012 01:09 PM
