Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Australia
Old 03-20-2007, 01:34 AM   #1
gary
Drives: yaris
advantages of alloy wheels
Hi, I'm new in here, I have a 2006 Yaris YRS. I'm wondering if I should replace my steel wheel into alloy wheel? If so, what are the advantages if I change into alloy. I have my eye on the Toyota Incisor allow wheel 15"x6' Thanks.
gary is offline   Reply With Quote
Old 03-20-2007, 05:50 AM   #2
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
they look better than hubcaps......
plus i dont know the weight of steelies vs alloys but if the alloys are lighter than the steelies then you will accelerate a tad better......
Old 03-20-2007, 06:37 AM   #3
ASHRAF
Scubie Du
Drives: '10 SWP STi/'09 Escalade
Send a message via AIM to ASHRAF Send a message via MSN to ASHRAF Send a message via Yahoo to ASHRAF
if u increased the size of alloys and drop ur car a little
the car handling will be alot more better
Personally, I use 17"*7" xHP and they are awesome
-AJ
'05 Black Toyota Avalon Limited - Saudi Arabia
'06 Black Sand Pearl Toyota Yaris YR - Australia
'08 Fiji Blue Pearl Honda Civic Mugen Si - US
'08 Lightning Red Subaru Impreza WRX STi - US
'09 Diamond White Pearl Cadillac Escalade - US (current)
'10 Satin White Pearl Subaru Impreza WRX STi - US (current)
'11 Yaris?
ASHRAF is offline   Reply With Quote
Old 03-21-2007, 01:13 AM   #4
as400g33k
as400g33k's Avatar
Drives: 05 YRS Silver Lining Metallic
Mostly for looks only.
as400g33k is offline   Reply With Quote
Old 01-03-2010, 07:51 AM   #5
plawrenc
Filgor
Drives: Yaris YRS 2007
Hi Gary,
this response is late , so I hope you have already fitted some nice alloys..
Alloy wheels are noticeably lighter than the steels that come standard.
When I first changed to alloys this was particularly noticeable when manualy rotating wheels. The absence of hub caps also makes rotating wheels and changing flat tyres a little easier.
In terms of handling, the lighter wheels respond more quickly to the suspension springs in rough conditions, giving better traction on uneven surfaces particularly when cornering.
I'm assuming your car has 15x5.5" steel wheels fitted; in this case the incisors you mentioned are a wider rim which will only slightly improve responsiveness of the steering, braking and acceleration. You will however be able to recycle the stock tyres.
Normally when switching to alloys people go for a larger diameter wheel and wider rim which results in noticably better steering response, less rocking during braking and acceleration, but a rougher ride.
The main feature that you will gain from moving from the standard wheels to alloys is the look. They look awesome! They are also more open, making the brake mechanism miore visible for inspection and give the car a sportier look.
In general, The larger the wheels, the sportier the car looks and handles but the rougher the ride.
The most critical downside is that if you scratch your alloys on the kerb, they cannot be replaced cheaply. This is critical if you are not cautious when taking corners and parking.
I recommend changeing to alloy wheels as soon as the stock tyres wear out.
plawrenc is offline   Reply With Quote
Old 03-15-2010, 02:15 AM   #6
SmellyTofu
好多人&
Drives: .
I have a set of 15" Toyota genuine wheels for sale in Sydney (from Toyota Japan). It has some scratches thanks to an inconsiderate tyre installer.
Let me know if you are interested as it's filling up my garage and I have no car to fit these on
btw, $250 for the set of 4
SmellyTofu is offline   Reply With Quote
Old 03-15-2010, 02:33 AM   #7
*MAD DOG*
*MAD DOG*'s Avatar
You can if you want to. If you change to alloy the wheel should be lighter than the stock steel rims, so you should have a minor acceleration improvement.
However a steel rim keeps the pressure in the tyre better than an alloy rim. So you may have to check your tyre pressure more often with an alloy rim. Also check with your insurance company first before putting anything on your car, you'd hate to have them not pay because you werent stock.
To be honest the best mod you can do to your car is a NST 10% Underdrive Crank Pulley. Both NST and Micro Image, vendors on Yarisworld sell these. I'd get one of these over wheels for sure.
Old 03-21-2010, 11:58 AM   #8
Speedz
Will work for Yaris...
Speedz's Avatar
Drives: Yaris
What does the underdrive crank pulley does in terms of better performance? Im doing a 80k km service and might sneak that one in... :P
Speedz is offline   Reply With Quote
Old 03-21-2010, 12:27 PM   #9
YarisSedan
YarisSedan's Avatar
Drives: 08 Yaris Sedan
Send a message via AIM to YarisSedan
Also your vehicle will "ride" better. Alloy wheels flex a bit so it acts like a second shock absorber. Thats why lots of the luxury cars come with alloys from the factory.
The downside though is usually when people get alloys they get a thinner sidewall because they like the look or they want to step up on a rim size so then its offset by the fact you have a smaller stiffer sidewall.
Old 03-21-2010, 12:40 PM   #10
TwoBearWisconsin
TwoBearWisconsin's Avatar
Drives: 2010 Yaris LB/5, 1996 Miata
Two questions - what does the stock 15" steelie weigh? and what happens if the alloy wheel doesn't accept the tpms?
TwoBearWisconsin is offline   Reply With Quote
Old 03-21-2010, 07:53 PM   #11
*MAD DOG*
*MAD DOG*'s Avatar
Faster acceleration off the line and less strain on the engine. Pm cali yaris for one.
Old 03-21-2010, 09:27 PM   #12
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
lol, it is always fun to see one of these 'original' threads of 2006 popping up now and again, reminds me of the old peeps.
The steel stockies weigh 16 lbs according to wheelweights.net.
Colin Chapman disciple
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
Do bigger wheels and tires improve performance Driver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 10-14-2006 06:01 PM
Enkei RZ5 wheels on Liftback kennywhy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-23-2006 04:22 AM
