11-19-2018, 03:41 AM | #1 |
Yaris cabin "breath out" hole
Hi folks,
the previous car I drove (Mitsubishi Galant) as well as the other cars I met had a well hidden hole with rubber cap somewhere in the interior. The only purpose of the hole was to let the pressurized air flow away when closing door as in certain moment the door seal was already sealed but the door still moved towards a full close which means a pressure built up inside the cabin for short time. That hole helped to mitigate this. That means that in my previous car I did not have to extra-SLAM the door when I was closing the last one. Does Yaris have something like that? Probably not (or if yes then it is clogged). Because when I am closing the door I really have to extra-SLAM the last one, especially when cabin external air blower is engaged. It is not a problem of the door hardware because when I keep any window a bit opened then the problem disappears. It is nothing major, I can live with that. Maybe this thing is only installed in some expensive limousines and not in wheeled candies like Yaris. |
11-19-2018, 07:06 AM | #2 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Seems like it would hurt your eardrums, I don't have that problem on my Yaris.
11-19-2018, 09:11 AM | #3 |
There are one way valve holes at the back of the car. You would see them on each side when the bumper cover is off.
Sent from my CLT-L04 using Tapatalk |
11-19-2018, 01:03 PM | #4 |
Yaris Hybrid Limited 2015
11-20-2018, 03:05 PM | #5 |
Thanks folks, will check them out!
11-20-2018, 04:27 PM | #6 |
mine must be broken or something because my cabin fogs up. any solutions?
11-21-2018, 09:04 AM | #7 |
Drives: 2007 Join Date: Feb 2014
You may have a water leak, not uncommon.
Number of threads on here about it. Check your carpeting for moisture and the spare tire well. |
11-21-2018, 09:14 AM | #8 |
11-28-2018, 12:17 AM | #9 |
Drives: 2018 Yaris LE liftback, 2020 Join Date: Sep 2018
Check A/C drain. Also, use the "outside air" selection on fan in cooler weather, instead of "recirculate", which is meant for cooling a hot car in summer.
11-28-2018, 07:44 AM | #10 |
Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
Cabin pressure is relieved via the air extractors located behind the rear bumper cover. Yours may be stuck closed some how (maybe a ton of spider webs or other debris are preventing the rubber flaps from opening when the doors are shut).
11-28-2018, 07:46 AM | #11 |
Clean the inside of your windows. I noticed that if I'm lazy and haven't wiped down the inside of my windows, they fog up easier when there is an imbalance of temperature between the cabin and the ambient temp.
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
2015 Yaris SE (m/t) - Week-One Impressions - The Good, The Bad, & The Ugly. | Kalispel | Third Gen Yaris General Discussion | 53 | 04-29-2016 10:35 AM |
FS: Various Parts from a 2009 Yaris Hatchback | Freestylin | Items for Sale by private party | 17 | 02-24-2016 09:36 PM |
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) | Murtaza_murti | DIY / Maintenance / Service | 5 | 04-05-2012 11:03 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
