Old 04-02-2017, 01:47 PM   #1
Mickman
Drives: 2006 Yaris RS
Battery Light Flicker
Hey everyone,
I apologize if this has been answered already, I tried searching but couldn't find a clear answer.
Left my 2006 Yaris Hatch sitting for a week while we were on vacation. Came home and started no problem but the battery light is on (flickering).
Voltage was 11.3 with car off, 13.5-13.7 running, and now rests at about 12.5 when the car is off.
I turned the car on, disconnected the battery, and the car ran perfectly fine off of the alternator alone.
I read about the voltage regulator issues, is that what this sounds like to you guys? Car is still driving fine, seems to be charging at the right voltage as well.
What steps should I be taking?
Any help would be greatly appreciated.
Mike
Mickman is offline   Reply With Quote
Old 04-02-2017, 03:39 PM   #2
Almost definitely the voltage regulator. If you just now returned from vacation, then the car has recently been subjected to very moist air conditions. When mine initially started to show signs of failing, it happened during rain or heavy fog events. Went away when things dried out again, then back to flickering when the next wet atmospheric conditions occurred. This went on for several years before I finally had a permanent battery light rather than intermittent flickering. Replaced alternator at that time.
Old 04-02-2017, 07:12 PM   #3
Mickman
Thanks for confirming my suspicion. Do I have time to replace this or should it be done ASAP? Reason I ask, is it is cheaper to order from Rockauto rather than buy local. I'm sure you can relate as I see you're in Canada as well!
Old 04-02-2017, 07:46 PM   #4
An excellent seller and local.
http://www.yarisworld.com/forums/showthread.php?t=57949
Old 04-10-2017, 01:59 PM   #5
Mickman
So before I replaced the alternator, I thought I would take the alternator out and clean all the contacts and voltage regulator to see if the problem was corrosion. Put it all back together and the light flickers more and was off for a little bit but still no fix.
But now the car idles low and rough.. is this because the ECM is relearning after the battery disconnect? Drove 30+KM and still like this. Tried playing with the belt tension and no luck either.
Help!! lol
Old 04-10-2017, 02:15 PM   #6
tmontague
tmontague's Avatar
Your car will fluctuate revs and idle higher sometimes when the ecu is relearning, that part is definitely normal and happens to me whenever I unplug the battery
Old 04-10-2017, 09:10 PM   #7
Mickman
Thanks man! Just wanted to make sure. Should be back to normal soon.
Old 05-04-2017, 05:03 PM   #8
Mickman
Just wanted to update. Got the alternator fixed and now all is good.
Big thank you to tmontague for the alternator (Great seller) and pointing me in the right direction after I blew the main fusible link while rushing and forgetting to disconnect the battery during the alternator change.
Thanks everyone!
Old 05-04-2017, 05:09 PM   #9
Excellent.
Old 05-06-2017, 09:56 PM   #10
xdarkxfirex
Drives: 2015 yaris le
Check for draw, battery and connections before ruling out a bad alternator. Most problems start at the connections
xdarkxfirex is offline   Reply With Quote
Old 05-06-2017, 10:58 PM   #11
tmontague
tmontague's Avatar
^the op just stated the alternator fixed his issue. It was a bad regulator in the alternator
Old 05-13-2017, 05:18 PM   #12
The_OB_YA-Rice
Toyota Tech
The_OB_YA-Rice's Avatar
Drives: 2007 Toyota Yaris
This thread is probably pretty old, but I can almost promise you its the alternator, mine does the same, and I work for Toyota and know that in some yaris' there is a connection in the alternator that can rust and require you to get a new one.
The best rice. The Ya-rice.
My goal is to be faster than those people in their Hondas and Subarus.
The_OB_YA-Rice is offline   Reply With Quote
Old 05-13-2017, 06:19 PM   #13
^ another newbie who doesn't read entire thread. This issue has been resolved.
Old 08-16-2021, 11:09 AM   #14
Trickster
Drives: '08 Yaris Hatch MT
I am having the same issue. I'm so happy to find this thread to confirm my suspicions of my alternator going bad.
I appreciate you guys posting these things. It's extremely helpful.
Thanks!
Trickster is offline   Reply With Quote
Old 08-20-2021, 02:44 PM   #15
zoidberg444
zoidberg444's Avatar
This happened to my alternator back in December 2014. I thought I noticed a light flicker on, on the dash a few times when driving. Then one evening I get in it and its on permanently. It was weird as well, at idle it would sit at 14V but when driving with a lot of load on it you could tell the alternator was dropping out and the electrical system was under volting. Changed it for a re manufactured one and it was fine.
UK to Nordkapp in a Yaris
Remote for remote starter draining its own battery. bad DIY / Maintenance / Service 4 11-01-2015 01:00 PM
Battery Warning Light - Different Twist maybe RutherfordmanX DIY / Maintenance / Service 3 06-08-2015 08:59 PM
battery light on and off yariseggvvti DIY / Maintenance / Service 43 05-04-2014 11:18 AM
Charging System Light N9QGS DIY / Maintenance / Service 1 07-26-2010 06:53 PM
Light weight race battery. buddyjim Performance Modifications 24 01-27-2009 08:33 PM
