01-26-2009, 10:59 PM | #1 |
Right beside you, wave
Drives: 08 PBM Yaris Sedan Join Date: Oct 2008
New wheel ?
I have a set of 17x7.5 Maas rims. This is my question. I had to have hubcentric rings on the tC, but I am not sure about my Yaris sedan. The dealership has been no help and I searched, but didn't find much here.
How do I find out what size I need or even if I need them at all. I want to put a spacer in the rear to make the rear fit flush with the fender. Any answers and suggestions will be appreciated.
2008 Toyota Yaris Sedan. Pacific Blue Mica. Custom vinyl eyebrows, color matched interior trim pieces, Vios lip spoiler, 17" Maas rims 2010 Scion xB 7.0 Release Series. 1535 of 2000. Murasaki. Stock with TRD springs. |
01-26-2009, 11:16 PM | #2 |
What exactly is the question?
01-26-2009, 11:59 PM | #3 |
Do I need a hubcentric ring for the yaris? Sorry, new to this car, still used to Scions.
01-27-2009, 12:24 AM | #4 |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
uh. well, i have VERY wide wheels and tires on my sedan, and they almost rub in the back, and when i ran a slightly wider tire, they did rub in the front. i would think that if you have a wide enough rim like mine, with a wide series of tire, that you wouldnt need a spacer for that. and if you drop it, i doubt you could go out much further than mine are.
note: i am running taller/wider tires on a 17" rim to help fill the gap because i dont plan on lowering the car soon due to finances and because of the roads and driveways around here.
01-27-2009, 04:10 AM | #5 |
Thanks. I don't like really low profile tires either. Well I guess I don't need the spacer or hubcentric ring. Now to wait for my tires to be delivered and mounted before I can put them on.
01-27-2009, 08:55 AM | #6 |
lol hubcentric rings have nothing to do w/ spacers....
if the center bore of your aftermarket rims are bigger than the hub of your yaris (which it almost certainly is) you should get hub rings for your rims.... hub centers on aftermarket rims are often in the area of 73mm so they can be used on a wide variety of vehicles....iirc, the yaris centers are 53.1mm (same as a miata)
01-27-2009, 04:27 PM | #7 |
Sweet. Thanks.
01-27-2009, 05:13 PM | #8 |
Hubcentric rings are the way to go. They make for a tight fitment and may eliminate vibration at speed. Maas wheels are available from many shops, so just contact one, tell them the model name and your application, and have them send you the rings. Or, call Mass Wheels directly @ 866-978-4737.
01-28-2009, 11:32 AM | #9 |
thanks for the number. I have the boxes, but my computer won't let me access their website.
01-28-2009, 12:17 PM | #10 |
Similar Threads | ||||
OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
Slightly damaged wheel | aucorium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 12-06-2008 07:06 AM |
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
Yaris wheel rate ratio (06+) ? | dsc_pat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 07-05-2007 05:43 PM |
