Old 10-21-2014, 08:40 AM   #19
The bent rim idea is a good one for the rubbing piece. Swap the front and rear tires on that side and see if the rubbing goes and the vibration moves.
He does state in the first post that tire rotation has been tried.
OP, edit one of your photos to draw a circle around the exact spot where contact is being made between caliper and rim.
Old 10-21-2014, 06:25 PM   #20
Echospeed
Drives: 2002 Toyota Echo Coupe
Turns out it was a badly bent rim causing the trouble. It got rotated to the rear for now. That being said, is a replacement steelie worth it or should I just go on and get new wheels? If so, what would be a safe dimension to move up to for a slightly larger wheel size?
Echospeed is offline   Reply With Quote
Old 10-21-2014, 06:36 PM   #21
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Try your local salvage yard. There's usually cheep used ones available.
Sent from my iPod Touch
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Rim 13" or 14" Yaris Hatchback 2008 Bearmantle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-19-2013 12:11 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Rubbing Issues RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-12-2010 08:26 PM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
