Old 11-29-2017, 04:34 AM   #1
S2000
Drives: Honda S2000, Toyota Yaris 1.3
Toyota Yaris 1.3 vvti -99
Hi!
Does anyone have this kind of issue and how to you handle it. Or do you have solution that problem I have.
Now its time to get my wintercar on the run.
I faced a problem. My Yaris will start, running 2 seconds and then turn off.
I have cleaned MAF sensor and checked cylinder number 1 and 2, and they give a spark. I´ve done that because check engine light is on and OBD error code says P1305.
Internet says:
Possible causes Faulty Ignition Coil No. 2
Ignition Coil No. 2 harness is open or shorted
Ignition Coil No. 2 circuit poor electrical connection
Faulty Engine Control Module (ECM).
S2000 is offline   Reply With Quote
Old 12-08-2017, 06:02 AM   #2
S2000
Problem solved.
Signal wire to ECM was broken.
Slow from cold Yaris 1.3 VVTI f2raf DIY / Maintenance / Service 2 03-01-2016 08:42 PM
Toyota Yaris 1.3 SR 2007 Start Up Problem Kishan2511 DIY / Maintenance / Service 6 05-08-2014 07:22 PM
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW VitzBoy General Yaris / Vitz Discussion 5 09-05-2010 08:53 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
