Old 12-18-2018, 08:14 AM   #1
Miyagigoose
Drives: Yaris mk2
Mk2 yaris 1.0 Rad fan relay help
Noticed no matter how long the cars running the radiator fan does not cut in anymore, also doesn't run when the aircon is switched on. I'm guessing its the fan relay doing research on these seems to be the most common failure.
Fuses are all OK fan turns freely.
Problem I'm having is I don't have any manual not sure where its located its 06 mk2 with the 1krfe engine, thanks in advance.
Miyagigoose is offline   Reply With Quote
Old 12-18-2018, 08:28 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
should be in the fuse box in the engine bay. Open the cover and it should tell you what relay is what.
Old 12-18-2018, 08:46 AM   #3
Miyagigoose
Drives: Yaris mk2
Its like a white box in a metal bracket with a cable and connector on the end def not in fusebox its too big
Old 12-18-2018, 08:47 AM   #4
Miyagigoose
Drives: Yaris mk2
Found it , down near the left hand side arch, thanks all
Old 12-18-2018, 10:40 AM   #5
Bluevitz-rs
That’s not the relay, that the 2 speed resistor.
You’re welcome.
Yaris 1.0 not starting...please help! Dave G DIY / Maintenance / Service 1 09-17-2013 05:45 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Question: Yaris' Radiator Fan: Electrical or Clutch-type? TRD_Yaris General Yaris / Vitz Discussion 5 06-11-2006 09:07 PM
