Old 11-28-2016, 07:58 PM   #1
guy2can
guy2can
Drives: 2012 Yaris SE
P/S Pressure Switch P0552
Hi all,
Had to change the power steering pressure switch (PN: 89448-51010)on my sons 2004 Echo HB, the code P0552 was coming up once the car was started after every code clear. I tried cleaning the connector, but in the end went to the wreckers and paid $20.00 CAD for a used one. From the dealer and parts places, this little baby is $275-300 CAD. It is about $125. USD at Autozone under PN: PS442.
So changing was fairly easy with the car on ramps and accessing the switch from below with a 1 1/16 wrench. The hardest part was getting the connector to release without breaking the lock. The K Ohms readings in the amber column were alot more on the bad sensor.
cheers,
guy2can is offline   Reply With Quote
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 53 11-12-2017 03:03 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
